In trying to simplify the footprint, our house design now has a 48' long wall with 6 windows (two 3'w x 4'h, two 3'w x 1.5'h, and two 2'w x 6'h). The following extract from Section 6-1 in the Logix Design Manual says
"...Tables 3A and 3B provides reinforcement tables for LOGIX walls used above-grade.
Building limitations used to develop Tables 2A to 2D, and Tables 3A and 3B include:
Building perimeter = 80 ft max x 40 ft max
Roof clear span = 40 ft max
Floor clear span = 32 ft max
Number of stories above grade = 2 max ..."
The long side of our home is less than 80LF, but there is the 48LF shorter side. Planning on using 6.25" forms. Walls would be 12ft from top of footing to top of wall. Above grade section of wall will be 9'8". Slab on grade.
1. Do I need to have the 48LF wall engineered for rebar vice using the prescriptive tables?
2. What is the difference between the Roof and Floor clear spans?
