JosephFearn
jeepster
| 29 Mar 2012 11:30 PM |
Looks pretty tricky. How well is that Nudura peel and stick working in the cold. I have to use a heat gun to get it to stick in the cold. |
arkie6
| 29 Mar 2012 11:53 PM |
What happens when that ground thaws? |
JosephFearn
| 03 Apr 2012 11:24 AM |
Contractor said that the ground wasn't frozen, just had a light snowfall a couple days before. I asked him the same question when I saw the pictures! |
| 05 Apr 2012 04:42 PM |
I must say that I don't understand the wisdom of a thermal bridge from the ground to the interior of the ICF.
jeepster
| 05 Apr 2012 08:27 PM |
Posted By jonr on 05 Apr 2012 04:42 PM
What would be the other option? Insulate under the footing? I know this has been discussed, but I don't know of any building code that will allow that. Plus, what insulation wouldn't compress under that much weight? I don't think that would be a good idea . . . . of course, I could be misunderstanding something. |
ICFHybrid
| 05 Apr 2012 09:53 PM |
Foam insulation comes in all sorts of densities, from the ones you see at the building supply all the way up to some truly dense specialty stuff. It's quite easy to design residential foundations to sit on it. |
| 06 Apr 2012 08:32 AM |
I agree - once the insulation is as strong as the soil, it's strong enough. The PSI load of a footing is actually reasonably low. I would consider using frost protected shallow thickened edge slabs (which code allows - no footings needed). |
yetanotherjohn
| 06 Apr 2012 10:54 PM |
Another option for under footing insulation is foamglas. Slightly lower R value than eps (R=~3.4) but ~90PSI rating (vs ~25 PSI for most undisturbed soil), impervious to water. Won't deform. Bugs can't eat through it. A little late for you project though. By the way, did you also pour the interior slab or will it be a floating slab poured later?
JosephFearn
| 09 Apr 2012 12:10 PM |
We have looked around for foamglas. But it isn't available yet in North America, to the best of my knowledge. They poured the slab later as the lower portion had to be backfilled |
yetanotherjohn
| 09 Apr 2012 01:02 PM |
The contact info for the foamglas is:
Pittsburgh Corning Corporation
800 Presque Isle Drive
Pittsburgh, PA 15239
USA
Phone: +1-724-327-6100
Toll Free (US/Canada) +1-800-545-5001
Fax: +1-724-387-3807
www.foamglas.us
Technical Manager
FOAMGLAS® Building
Howard Patrick
USA
Phone: +1-724-387-3624
Cell: +1-724-689-8344
Fax: +1-724-387-3806
[email protected] |
