Installing slate tile on ICF
Last Post 15 Feb 2016 01:55 PM by emmetbrick. 6 Replies.
lzerarcUser is Offline
16 Jan 2013 04:10 PM
We are wanting to install slate tiles (about 1/2" thick, 12x24") on the exterior of our icf house. Any one done this before? I know the methods of installing stone and stone veneers, but I would think that would be over kill for thin tiles. My thought would be to install 1/2" backerboard via screws to the furring strips and install tile as normal onto that. The other thought was to screw up galvanized mesh and install a thick mortar bed/install tiles that way (not doing a scratch coat first). any thoughts?
22 Jan 2013 06:08 PM
Standard backerboards for tiles aren't rated for exterior use, and are likely self destruct over time due to freeze/thaw cycles.
papitoheadUser is Offline
24 Jan 2013 04:58 PM
It seems to me that backerboards will store humidity there and with the cold will probably crack. I have to agree with Dana1 on this.
29 Jan 2013 11:06 PM
so go with a mesh, scratch coat and then tile?
21 Jan 2016 08:29 PM
We are looking into installing a 1x1 slate tile 5' up on the interior of some ICF walls. A tile guy we work with said to use Platinum Thinset directly to clean EPS. Opinions?
26 Jan 2016 04:41 PM
My guess is that it would be fine.
emmetbrickUser is Offline
The underlayment should be what the tile guy will warranty. A scratch coat will work. Better for you if it is a scratch coat of his choosing. Mesh definitely
People Online People Online: Visitors Visitors: 278 Members Members: 0 Total Total: 278
