What are your thoughts on Quad-Lock?? (good and bad)
Last Post 30 Jul 2013 10:25 PM by arkie6. 65 Replies.
Page 4 of 4 << < 1234
d'techguyUser is Offline
25 Jul 2013 02:54 PM
Roger, it depends on the system. Quad-Lock does not suggest that panels should be glued together. The exception might be a radiused wall, but even that is doubtful.
Other systems may suggest adhesive between courses, but check their published installation instruction.
d
arkie6User is Offline
25 Jul 2013 07:06 PM
I built my home using LiteForm ICF which is similar to Quad-Lock. I did not glue any panels together and did not apply any bracing or strapping on the outside. All of my bracing was on the inside and secured to the ICF. I had no floating of the forms anywhere - no gaps opened between the panels for either my basement pour or my main floor pour. But one thing I did do was put some load on my forms by lifting my vertical rebar off the bottom ~1/2" and tying it to the top horizontal rebar so that the vertical rebar was hanging from the top. This put some additional weight on the forms. I also had rebar every 16" horizontal and every 16" vertical.
Roger RUser is Offline
29 Jul 2013 09:55 PM
Posted By arkie6 on 25 Jul 2013 07:06 PM
Arkie, Hanging the rebar seems like a great idea to create 'weight' to hold down the works. Did they get cocked up when the pressure of the falling concrete moved them?
29 Jul 2013 09:58 PM
Posted By d'techguy on 25 Jul 2013 02:54 PM
...Quad-Lock does not suggest that panels should be glued together. The exception might be a radiused wall, but even that is doubtful.
D'techguy, Why don't they "suggest it"? Is it because it is not at all necessary - or does it create "other" potential problems? If it's the other potential problems,what are those problems?
30 Jul 2013 07:53 PM
Installers have never found it necessary to foam Quad-Lock panels together. The design of the system is intended to prevent floating.
d
Posted By Roger R on 29 Jul 2013 09:55 PM
The bottom of my vertical rebar was restrained from moving more than 1" or so by PVC pipe rings that I had attached to the rebar dowels in my footing.
People Online People Online: Visitors Visitors: 217 Members Members: 0 Total Total: 217
