Looking for an ICF professional for Bracing and Pouring
Last Post 25 Dec 2013 03:06 PM by
eric monkman
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
tweeterisu
15 Dec 2013 05:22 PM
Getting started on our new build and would like to find an ICF installer who has experience bracing and pouring walls. We will be using the Hobbs VICF system. We are located in Des Moines, IA. Let me know! Thanks, Matt
ICFBdr
16 Dec 2013 12:20 PM
Rather than forcing a contractor to use a system you choose, you may be better off letting the contractor choose the product. If an installer is using a product they are not familiar with, there is a chance that either (a) the quality of the work may suffer or (b) the install price will increase to account for the learning curve associated with a new product. This is especially true when you decide to use a vertical system, as the vast majority of installers have used only horizontal ICFs.
krom
17 Dec 2013 09:10 PM
should be an easy job for any concrete guys to do. The bracing hobbs specs is identical to what is used with normal forms
davidhopke
18 Dec 2013 10:16 PM
Hobbs should be able to recommend a contractor. The ICF block type manufacturers have a good network for each of their respective brands.. I would think Hobbs should be able to recommend an installer
eric monkman
The selection of concrete mix design for Waffle Grid Systems is critical.
You only have 2 inches thick in the web space with Hobbs.
Find a successful experienced Hobbs installer, factory trained.
Membership:
croccohvacusa
People Online:
