I used the Black Jack Ultra-Roof 1000 elastomeric roof coating to "prime" my ICF basement walls (2 coats) before applying TAMCO peel-and-stick water proofing membrane. It worked great.
Here is a window flashing thread from 2012 where I discussed the Black Jack elastomeric roof coating:
http://greenbuildingweb.com/Forums/...fault.aspx The good thing about the Black Jack is you can order it online and pick it up at your local Lowes.
http://www.lowes.com/pd_139941-29-5530-1-30_0__?productId=3013309
