Nudura ICF to Log Wall Connection Detail?
Last Post 08 Aug 2015 02:36 PM by
NuduraDustin
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
cbryndal
05 Aug 2015 12:05 AM
Looking at building a couple of small 1-room cabins. Would like to use Nudura ICF as the foundation/crawl space walls. Log walls will be built with square (hewn) 8.5" wide x 12" tall log beams. Looking for a great connection detail approach to keep out rain, snow, insects between the logs and the ICF. Thanks in Advance! Rgds, Corey..
FBBP
05 Aug 2015 02:02 AM
Cut a kerf in the bottom of the bottom log about 1.5" from the front. Fill the kerf with a non harding sealant like acoustic caulk and Insert a Z style drip edge with the top leg in the kerf. The drip part will then hang over the ICF. Make sure the horizontal part of the flashing is long enough to push the drip about 1/2" ahead of the ICF to allow for parging the ICF. Caulking should also be placed on the underside of the flashing to seal it to the concrete.
Logs can be attached with oversized j bolts or a combination of j bolts and ready rod depending on how the logs will be fastened to each other.
Remember that log shrink (a lot) and leave settling gaps above doors and windows.
cbryndal
05 Aug 2015 10:27 AM
Thanks, FBBP. I'll try to draw up what I think you're describing. If you have a photo or drawing could you share it?
ICFSalesDustin
Contact Keegan Still at Nudura. I am pretty sure he has a detail that can help you with your design questions. (705) 726-9499 let him know what your needing and he can help.
Membership:
croccohvacusa
People Online:
