IS your concrete poured? Did the pour go OK, and were the walls trued up at the end of the pour? IT could be that the inconsistencies in your blocks were caused "post expansion"(foam didn't expand consistentely or shrunk back) and that is what they are refering to IRT your blocks. The gaps should be foamed to contain the concrete and maintan your insulation characteristics. Your engineer shouldn't really care as the forms are not really structural after the concrete cures, beyond containing the concrete and positioning the rebar to the designed locations... Because the ties are not resting directly on top of one another the wall may settle a little more in that area, but probably not very much, and the contractor ahould be aware and able to compensate for that. Maybe it will help to look at it this way. Once the concrete cures, it is a re-enforced concrete wall(engineered to a structural design spec) with embeded ties and foam hanging off of it. Inconsistent building materials happen. Your contractor should be able to deal with that and produce a finished product that is acceptable to you. |
