Posted By smartwall on 01 Jan 2016 01:14 PM
You can use a power finish nail gun to install baseboard and other trim directly into the webs of most blocks. Give a try with a scrap of block. I tried it about 10 years ago and the only way to remove the nail is by twisting as you pull. More that enough holding power for trim. You just have to mark the webs on the floor before dry wall is installed
Agreed - just nail directly into the webs (test piece is a good idea, since not all blocks/plastics are created equal). A larger gauge nail (I use 16 gauge) holds well in the ties. Most drywallers will leave the bottom screw exposed, so you don't need to mark the web locations. Just place a piece of painters tape on the floor to mark a web, then stretch out a tape measure - every 8" (or 6") will be a web (ignoring vertical stacks).
