Posted By dukebowling on 10 May 2017 07:25 PM
Was hoping for a monolithic structure, but will probably settle for simplicity.
Depending on how you're structuring, something like QuadDeck CAN get you to a monolithic structure.
Tilt-up
might be simpler, a lot of it depends on the design and how flexible you are with said design.
If you're looking at an A-frame that's mostly wall structure and no "eaves", a pour-in-place setup with stepped fill points could make a lot of sense.
You just need to provide structural tie-backs for the roofing surface back into the concrete/rebar system. You can even add rigid insulation over the surface to complete the insulation envelope.
Build the "box" for the roof surface, and leave ever other (or every third) row of plywood uncaulked/sealed/adhesived so they can be removed to provide a fill point.
Then fill the roof structure to just below the top of the panel below it.
Then caulk/seal/adhesive the row of panels back into place and screw them down.
Then fill from further up.
