Sill plate on I-Beam needs to be bolted?
Last Post 28 Aug 2017 01:15 AM by icfbound. 3 Replies.
rogeriusUser is Offline
27 Aug 2017 09:16 PM
Just finished pouring the wall basement, 8 rows, 10'-8" tall wall, 6" cavity, AMVIC 3.30 forms. Overall was a great pour of 34 cubic meter 25Mpa concrete. No major issues, just the tape to protect the foam was damaged, so will have some fun cleaning the interlocks to install the foam for next level. Now I've got a question and appreciate any suggestion. When the sill plate is installed on the I-Beam, do you guys drill holes in the I-Beam and attach the sill plate with screws? In my existing house and saw couple pictures on the net the sill plate just held on I-Beam by bent nails on the edge. Thanks.
icfboundUser is Offline
27 Aug 2017 10:35 PM
What I-beam? Bent nails?
Normally place L-bolts at top of wall @ 4' OC. Then drill holes in sill plate and use 3" square foundation washers and nuts to fasten. Need to place the L-bolts so don't interfere with trusses and catch all the ends of sill plate lumber.
CONservative: The first three letters are all you need to know to fully understand this Republican.
<br /> <br />
Racist: A person who believes their race is superior to another race.
<br /> <br />
Religion: The deception of suckers who fear nonexistence to believe in a nonexistent supreme being and to adhere to false doctrine to control and exploit them.
<br /> <br />
Republican: A greedy, racist, sexist person who skillfully uses deception, hate, fear and religion to control and exploit suckers to gain personal wealth and power to benefit themselves while using government to limit the freedoms, safety and pursuit of happiness of others.
<br /> <br />
Sexist: A person who assaults, discriminates, intimidates or stereotypes the opposite sex.
<br /> <br />
Sucker: A weak minded person who has been brain washed and who usually lacks education and critical thinking skills allowing them to be easily deceived. <a href="https://www.youtube.com/watch?v=vGAqYNFQdZ4">Watch...Don't Be a Sucker!</a>
<br /> <br />
Trumpian: A narcissistic and skilled con artist Republican who is highly attractive to suckers and uses Fascist and Nazi tactics and commits traitorous acts to undermine democracy to gain personal wealth and power.
27 Aug 2017 11:20 PM
Posted By icfbound on 27 Aug 2017 10:35 PM
The I-beam on which the joists are sitting. Bent nails are can be seen here: https://i.stack.imgur.com/J4c3U.jpg I know about the sill plate under the trusses but not sure about one on top of the I beam
I have seen this done by bolting double 2x lumber to the top and inside of the steel beam. Then the joist is fastened with joist connectors as normal. No one should drill holes in an I-beam without first consulting the structural engineer. In fact, the structural engineer should tell you how they want this done.
<br /> <br />
<br /> <br />
<br /> <br />
<br /> <br />
<br /> <br />
<br /> <br />
People Online People Online: Visitors Visitors: 361 Members Members: 0 Total Total: 361
