ICF leaking below grade, looking for tips on diagnosis
Last Post 04 Feb 2021 04:48 AM by Jay Rousseau. 62 Replies.
Page 4 of 4 << < 1234
Author Messages Not Resolved
Jay RousseauUser is Offline
03 Feb 2021 05:58 AM
Thank you for sharing your knowledge and experience, it is truly appreciated. I haven't thought about voids in the foundation walls, so it is a good and new thing to me to look for when we strip the foam around these wet areas. We would like to fix those voids too. We definitely will put in a dimpled Superseal layer, its benefit is well documented on the Internet as in relieving water pressure as well as protecting the "waterproofing membrane" (which is the Soprema p-s sheets, I guess) during backfill. I noticed my neighbor on the west side covered a section of his walls with a dimpled membrane a few years ago as well. It is a pity, even a sin, that a dimpled membrane was not installed around foundation walls in the first place. I now feel a little better that excavation can be done with an excavator with a mini track hoe, it gives me hope that it won't be super expensive. Thank you for this tip.
My last question is what I should do with the existing p-s sheets ? Thanks again for your valuable inputs.
smartwallUser is Offline
03 Feb 2021 02:22 PM
You should find damage or puckers in the seams so clean the area and use a product called Protecto Wrap. You can get small rolls on the web. It's bullet proof and will stick to anything including glass, Good luck. Oh it's called Primer Free
Many thanks for all the help you freely gave. Sincerely.
People Online People Online: Visitors Visitors: 268 Members Members: 0 Total Total: 268
