Anchor bolt distance from edge
Last Post 18 Dec 2018 05:24 PM by arkie6. 2 Replies.
17 Dec 2018 01:46 PM
Is there a code requirement for the concrete coverage over 1/2" anchor bolts? Another words how close to the edge of the concrete on top of a wall? Or would we just follow 1/2" rebar coverage?
smartwallUser is Offline
18 Dec 2018 03:32 PM
The only one I've seen is 5 times the diameter for lag anchors. So if you have a 1/2 " lag anchor you need to be 2.5" from the edge. I would think the same for anchor bolts. The 1.5" for rebar is to make sure the rebar is covered, but there is no pressure on rebar like anchor bolts.
arkie6User is Offline
Are we talking cast-in-place J bolt anchors or drill and drop in wedge or adhesive anchors?
What are you attaching to these anchors?
The 2012 IBC specifies a minimum concrete edge-to-anchor-center distance of 1-3/4" for anchors attaching a bottom plate to concrete foundation which makes sense when you are dealing with a 2x4 bottom plate.
https://codes.iccsafe.org/content/IBC2012/chapter-19-concrete
People Online People Online: Visitors Visitors: 379 Members Members: 0 Total Total: 379
