ICF Screws type
Last Post 04 Sep 2024 02:37 PM by smartwall. 3 Replies.
[email protected]User is Offline
31 Aug 2024 06:20 PM
I'm currently working on a foundation with nudura icf. I'm looking to see what type of screws work best for attaching bracing and also attaching 2 by material. Thank you
ICFBdrUser is Offline
03 Sep 2024 05:07 PM
Nudura supplies Hex head screws in 2", 2.5" and 3" lengths. They are the best concrete screws on the planet!!! I use them for bracing, footing forms, sidewalk forms, etc. Easy to install, hold solid and the hex head makes them easy to find and remove and concrete has cured (they are a bit pricy but can be used multiple times). You need to use the 3" length to attach 2X material (1.5" material + 5/8" EPS before you hit the web). If you are using the Nudura braces, it is important to note that the safety testing was done with these screws - using a different fastener may cause issues if OSHA ever takes a close look or if an accident occurs.
newbostonconstUser is Offline
04 Sep 2024 08:35 AM
Course screws are better going into plastic hangers. I would even do screws for backer board in showers for no rust.
smartwallUser is Offline
We use a self-piercing screw with a hex head drive. Easily reusable.
