SIPS and Steel Frame SIPS
Last Post 05 Mar 2007 12:36 PM by AZGraham. 5 Replies.
e-noUser is Offline
05 Dec 2006 11:14 AM
Hello,
Can anyone tell me where I can find structural section details etc. of Sips and Steel Frame Sips?
Bill ChaleffUser is Offline
06 Dec 2006 07:48 AM
e-no
I've used these fellows several times in the past with great success:
Coronis Building Systems
http://trussframe.com
(609) 723-2600
92 Coliumbus-Jobstown Road
P.O.Box 200
Columbus, NJ 08022
chopperUser is Offline
13 Feb 2007 06:02 PM
I've found a pretty good diagram on a favorite website: http://www.toolbase.org/TechInventory/TechCAD.aspx?ContentDetailID=975.
Haven't worked with Steel Frame.
Wish I could be of more help  -
Chris
1tightwadUser is Offline
15 Feb 2007 05:31 PM
e no,
When you refer to steel frame SIPS, are you talking about steel framing for the joists, trusses, and interior walls? I have seen one SIPS system that is PUR in the center and steel sheet on the either side; that is made by ACTech. Just trying to keep up with the terminology. Thanks
15 Feb 2007 05:45 PM
No , I am talking about painted galvalume steel skin SIPs with an EPS foam core usually 4" on walls and 6" + on roofs depending on your insulation requirements. Joints are male/female friction fit with no splines required. The base and pitched track is 18 ga. steel.
we then do the interior studs with light ga. steel framing
and any two story floor systems are hung off the interior of the skin using steel "Trade Ready" joist system and a 3/4" t&g plywood glued and fastened.
Ridge beams are done with 4" x 12" steel box beams, fabricated on the job.
We end up with a very termite resistive structure, we build through out Florida and can exceed any hurricane requirements
If you wanted to see details I can e mail a set in PDF
AZGrahamUser is Offline
Try www.energypanelsystems.com, we have added some of our details to our site.
People Online People Online: Visitors Visitors: 171 Members Members: 0 Total Total: 171
