Fiber-cement SIP
Last Post 12 May 2014 04:04 PM by Innova. 17 Replies.
engine44User is Offline
21 Feb 2007 03:18 PM
I am located in Indiana.  Does anyone know if the following product exists?
A fiber-cement SIP where the outside skin is prefinished similar to Hardie board products.
21 Feb 2007 04:24 PM
a company called T- Clear makes fiber cement sips
EZ-Build SystemsUser is Offline
21 Feb 2007 04:31 PM
You should be able to use whatever material you like on the outside of a fiber-cement SIP.  We have used T1-11 and Smart Panel.  Both are finished exterior products that can be applied to SIPS in factory.
SammyUser is Offline
21 Feb 2007 09:31 PM
You can do exactly what you are asking for. There is a company in Florence Alabama who will glady make and ship your panels to you. There name is Southeastern Building Panels and there phone # is 866-327-3057. You can get several types of exterior finishes and they do use the Hardie brand as well as others. They made the panels for my house and I must say that it has turned out very nice. I will be moving in very soon. Good Luck, Sam
Dick MillsUser is Offline
10 Mar 2007 04:07 PM
Sammy,
Did you have the Hardipanels placed on both sides?
And, did they laminate them directly to the EPS?
And, finally, when they erected the structure (and installed the doors and windows), I assume that the only remaining tasks were to caulk the joints, add some trim, and then paint it?
Dick Mills
12 Mar 2007 09:34 PM
Hey Dick, sorry about the late response to your post, I've been engulfed in my house for a few days. I do apoligize for misleading you. My panels are osb skinned. We used brick for the exterior and could not justify the upcharge for our panels just to cover it up. This was a hard decision to make also because you can get the Hardi put directly on the EPS. In the big picture it would have been much more econmical for me to have done this but my wife of 21 years asked me if I would like to make 22 years. I have seen the fiber cement panels put together several times and your assumptions are correct. It is a little more invloved than that but it is close. Putting in the doors and windows is real neat because they go in so fast, also assuming the panels are cut properly.  If you do decide to go with fibercement (good stuff) the weak link is in the transport of the panels. Shipping companies don't seem to have a clue as to what they are hauling they just ratchet the straps down until nothing can move. The panel company I used took some extra steps for me to make a safe journey for the panels. I hope this has been of some help.
Thanks, Sam Ramsey
In God I trust
pringstromUser is Offline
01 Apr 2007 11:27 AM
A company called ThermaSAVE in Florence, AL makes fibercement panels. They have four or five plants throughout the country with supposedly a new one in Richmond, IN coming this spring. They will even use the stucco simulated panels so that all you have to do is caulk the seams and paint. It is a very strong product and has passed several fire and shake tests (earthquake resistance) with flying colors. They will ship to where ever you are. I am planning to use them on my new house next year.
teufelhundUser is Offline
04 Apr 2007 11:03 AM
We have manufactured fiber cement SIPs for both domestic and international customers.  If you have any questions give us a call.
Global Building Solutions, LLC
2509 Clements Ferry Rd
Charleston, SC 29492-7635
Tel:  843-881-3590, ext 224
Fax:  843-881-3591
KathieUser is Offline
22 Sep 2007 06:03 PM
I'm using fcb skins from Global here in Charleston, SC & will post how all goes. I'm looking into using StoCoat Lotusan - exterior wall coating that "mimics the self cleaning capabilities of the lotus leaf." The environmental friendliness = no detergents or excessive water use to keep it clean.
Kathie
GWhittleALUser is Offline
12 Mar 2009 08:32 PM
Would it be feasible to make a fiber-cement SIP out of something like a Nichiha Brick Facade panel?  Does anyone do this?
I'd love to have the outside finished with the brick look (without the additional cost of laying brick or redundantly hanging Nichiha panels over fiber cement board SIPs), the inside ready for a natural clay plaster, and have all of the other labor saving advantages of fiber-cement SIPs.  I want fiber-cement SIPS, but my wife doesn't want stucco exterior walls...
What I think I'd really like is to use the stone Nichiha panels http://www.nichiha.com/prod_stone_panels.htm on the walkout basement and the chimney, and the brick http://www.nichiha.com/prod_brick_panels.htm on the other exterior walls.  Such a Nichiha Fiber Cement SIP, seems to me like a very good cost-saving combination.
Am I missing something (other than finding noone who has ever done this)?
regards,
Grant
13 Mar 2009 05:08 AM
Grant;
a good stucco man can do a brick or siding facade that you can't tell with out close examination.
many Wendy's  were done with colored stucco brick
ErgoDeskUser is Offline
16 Mar 2009 05:28 PM
You will find many GFRC Systems here: http://StyroHomeNews.blogspot.com
AntisthenesUser is Offline
16 Mar 2009 05:54 PM
sounds like you want Strataus.com ?
16 Mar 2009 06:06 PM
Including Strataus.com
SIPGUYNCUser is Offline
17 Mar 2009 10:50 PM
Grant,
To answer your fantastic question as to why nobody has thought of using Nichiha panels for "skins" is........... it has been considered by us over a year ago, but Nichiha engineers were unwilling to release engineering information regarding their products. they would only recommend their products for finishes only. Keep your hat on. We are working on it.
J.Jeff Harvey<br>PanelwerxSIPS<br>[email protected]<br>888-607-0538
InnovaUser is Offline
12 May 2014 08:44 AM
Innova Eco Building System manufactures cement fiber SIPs with James Hardie board skins. Our panels have Florida Product approval. For more information www.innovaecobuildingsystem.com
12 May 2014 03:42 PM
Posted By Innova on 12 May 2014 08:44 AM
How is the wiring done with your panels?
We install vertical and horizontal chases in our panels at no additional charge. Horizontal chases are at 15" AFF unless requested otherwise and Vertical chases are installed for switches.
