Posted By eknol on 06/25/2007 9:24 AM
I just have to worry that moisture from the outside does not come through. And by the correct corner / window / door details as well as caulking, that should be avoided. CORRECT OR NOT?
Not.
Building science professionals are coming to recognize that the reason old buildings didn't rot was not because they stayed dry by keeping moisture out, but because they had so many air passages that when they got wet, they dried out quickly. New house building techniques don't provide for near the air flow any more so now trapped moisture stays trapped. A tight envelope (such as the space between the wall and siding) will always have some air leaks. What happens is the envelope interior air expands and contracts with daily heating cooling cycles and it always sucks in more moisture than it expels, leading to a buildup of moisture in the closed space. Hence the need for a drain plane. You will also find advocates who will argue that around windows, doors, corner trim, siding board ends, etc. the best caulk is no caulk. Build the exterior finish configuration to shed water, not stop water. Accept the fact water will come through any siding system and provide a means for it to safely drain away.
