Transcon Steel Ultraframe SIPS
Last Post 17 Feb 2009 11:34 PM by JeffD. 28 Replies.
25 Aug 2008 07:02 PM
Posted By Alton on 08/25/2008 5:41 PM
Newhome,
I think climate can make a big difference in loss of energy.  The greater the difference in temperature from inside to outside, the greater the loss.  Am I wrong in this assumption?
Alton;
Bingo!  you are absolutely right.... it is the Temperature Difference that matters
and the reason why it is not so important  in moderate southern climates
25 Aug 2008 07:06 PM
Posted By newhome on 08/25/2008 5:45 PM
The point that if you could pick between two steel framed SIPs( not steel skinned) why would you not chose the one that saves the most energy regardless of your location and climate.
what system do you think is superior to them all?
newhomeUser is Offline
25 Aug 2008 07:33 PM
I was not saying that one system was superior. OSB, steel skinned or steel framed SIPS each bring different benifits to the table.
I am saying that all other things being equal why would I would chose a steel framed with no thermal bridging over one with thermal bridging. I have not used a steel framed SIP so could not recomend one.
25 Aug 2008 07:38 PM
Posted By newhome on 08/25/2008 7:33 PM
I haven't seen a system yet without a thermal bridge somehere, the key is to minimize them.
rnortmanUser is Offline
25 Aug 2008 07:50 PM
Posted By cmkavala on 08/25/2008 7:38 PM
Monolithic thin-shell concrete dome on monolithic ring beam footing and slab.  With no utility penetrations.  And no doors or windows.
ErgoDeskUser is Offline
25 Aug 2008 08:25 PM
I occasionally post my blog here for all to use as a reference and education into new Super Insulated Building Systems.
I don't endorse anyone and try to only promote the modern "Green building industry"
There are several systems that are very close to zero but like most I don't see why we should accept less...... or is that more?
I have worked on the insulated panel designs since 1964 and come-up with several excellent designs that I can't find anywhere in the industry, so I think that nobody cares at least no yet.
My Blog: http://StyroHomeNews.blogspot.com
26 Aug 2008 08:00 AM
Posted By rnortman on 08/25/2008 7:50 PM
[/quote]
rnortman;
Yea, a dome home, my deed restricted subdivision would love to see one of those babys in the neigborhood.
And no doors and windows?
 It doesn't matter if it has thermal bridging ,cause you can't get in and out of it anyway?
26 Aug 2008 09:12 AM
cmkavala,
Yes, I was only trying to reinforce your point, really, by pointing out that it could be done, but nobody would want to live in it.  Though more seriously, if you're willing to accept some windows and doors and utility penetrations, monolithic thin shell structures are otherwise free of thermal bridging (assuming spray foam insulation, of course).  But then you have to accept the dome shape, so it doesn't come without a price.
Of course, any flat wall system can be clad in rigid foam to cover up any bridging.  Or use spray foam if your walls aren't flat.  This is the only way to build stud walls IMO, and even with SIPs it could help in the areas where there's bridging, such as where the floor joists connect (depending on how you do that, there may be a lot of bridging or only a little).
http://structall.com/content/pdfs/Sec2_PriceBook.pdf
See above link for thermally broken channels that I typically use in my steel SIP building details.
People Online People Online: Visitors Visitors: 129 Members Members: 0 Total Total: 129
