Recessed can lights
Last Post 15 Aug 2008 07:54 AM by PanelCrafters. 1 Replies.
lkg907User is Offline
14 Aug 2008 07:14 PM
I'm just starting building a 1600 sq ft SIPs home in E. Washington.  6" walls with truss roof.
   I intend to "air seal" the attic area with 2" of sprayed in polyurethane foam and top that with R45 of cellulose.
   By design there is a bunch of recessed can lights.
   Do you think that the normal IC (insulation contact) fixtures will be OK in this application?  I'm assuming that someone manufactures these fixtures for use with some type of CF bulb.
Thanks in advance
Posted By lkg907 on 08/14/2008 7:14 PM
I wouldn't risk it. I would use ICAT (Insulation-Contact-Air-Tight). And, they make them for a variety of bulb types.
Good Luck!
People Online People Online: Visitors Visitors: 382 Members Members: 0 Total Total: 382
