Best Sips
Last Post 04 Mar 2009 09:42 PM by greentree. 29 Replies.
CANESUser is Offline
23 Feb 2009 07:36 PM
As I stated in a previous thread through my research in and interest in building a new home in South Florida, I thought that the AcTech Panel was the best.  With their situation right now, and possible exit from the market, I ask the experts on this board, which is the best type of SIP to build a structure from?  I am looking for strength in wind resistance, energy efficiency, quick assembly, fire resistance, termite and mold resistance.
Thank you all.
23 Feb 2009 08:04 PM
We can get you lower insurance rates with our panels
SimonDUser is Offline
28 Feb 2009 01:38 AM
If you want the best panel talk to Chris K. If you want the best drawings and design, talk to me.
Building Designer<br>PANELfusion, LLC, Tampa, FL<br>simon@panelfusion(dot com)<br>"Metal SIP Advocate"
28 Feb 2009 12:17 PM
CANES,
Actually, if you want a panel that is almost exactly like ACtechs panel in every way. Alumasheilds is the one you want. Similar lock configuration, 26ga G90 Steel, 2.4 #/cu ft Polyiso foam. I've designed several houses with them. They are located in Daytona Beach, FL
ps: If you are in South Florida, you need to meet impact codes for hurricanes and not every company jumps through those hoops to certify their panel, alumasheild might have that certification. It doesn't matter to me, if I know a material will work as a building component, I work around the bureaucracy.
The panels from Alumasheild that were used in the homes I've designed were 'B' grade panels. That means panels with a few cosmetic defects like scratches and peeling paint. In the right quantity, these panels can be purchased at quite a discounted price. They work fine for residential construction because they get covered up by other finishes like the siding and drywall. This is a good way to afford one of the best SIPs on the market.
28 Feb 2009 05:45 PM
SimonD,
I have used AC Tech panels.  Do you have a rough cost per SF for the B panels?  Which series and thickness would you recommend for the central part of Alabama?
28 Feb 2009 06:34 PM
Alton,
Don't want to discuss price on this forum, however, you can contact me privately for details. I've used the AW400 4" for walls and roof and also 6" for roofs, it depends on the project.
28 Feb 2009 06:45 PM
Here are some specs.
Attachment: aw400.jpg
28 Feb 2009 07:02 PM
panel type
Attachment: AW4001.jpg
Attachment: AW4002.jpg
28 Feb 2009 08:02 PM
Here's an interior closeup photo. You can see the ribs in the panel skin.
Attachment: IMG_0002.jpg
CTPUser is Offline
02 Mar 2009 02:45 PM
SimonD,
How do you achieve R-54.9 in a 6" panel? Also, why the need for all the furing strips? Just curious.
Craig
02 Mar 2009 03:24 PM
CTP,
I don't achieve R-54, thats what Alumasheilds specs say. I don't really get into splitting hairs over that kind of stuff because when an R-value is quoted, a temperature range needs to be posted with it, or it doen't really mean anything. All I know is that the R-value is up there and is superior to many wall and roof assemblies.
The furring provides a space to run electrical wiring or water supply piping before the wallboard goes on, so that you don't have to cut into the panel or conceal wiring/pipes so a building inspector can't see them..
ps: In the specs it says " R-value by ASTM C 236, you can look that test up to see its criteria.
KwikBuildUser is Offline
02 Mar 2009 06:13 PM
Using Kwik-Build Panels you do not need furring strips. Electrical chase ways are built-in. ON the exterior you can attach your siding or whatever type of exterior finish you like, directly to the panels. The interior can be drywall directly to the panels so again no furring. We have passed the test for Miami-Dade County, Florida for hurricanes. Our panels have been tested and held up to wind test of 225 mph.
They are also energy efficient, easy to assemble, 1 & 2 Hr fire resistance, termite and mold resistance.
Kwik-Build
02 Mar 2009 06:23 PM
Posted By KwikBuild on 03/02/2009 6:13 PM
Kwik-Build
KwikBuild;
 how would we view the 225 mph test results and the 1&2 hour fire resistance data?
Do you have a website for that?
randyfabalUser is Offline
02 Mar 2009 06:48 PM
Have you also applied for product approval with Miami-Dade for impact resistance and high velocity area use?
02 Mar 2009 08:32 PM
Yes we have, and have certification on high impact resistance test also!
Kwik-Build
02 Mar 2009 08:34 PM
Posted By KwikBuild on 03/02/2009 8:32 PM
Kwik-Build
Thats great how do we see it?
02 Mar 2009 09:02 PM
Tomorrow when I get into the office, I will put up the information to verify what I have stated!
Kwik-Build Panels
Haddock@ThermasaveUser is Offline
03 Mar 2009 09:28 AM
Our SIPS have the International Code Council Approval (see ICC Report #2406) and we also passed the Florida Building Code.  Our panels do not support mold and insects are not interested in trying to eat cement board or foam.  On average you can save 50% to 75% on your utility bills.  The panels come to your job site numbered and go together quickly. As for fire rating you can check our website thermasave and see our fire test as well as our earthquake test.  We currently have a 20 minute rating for homes and are in the process of getting a 1 hour for commercial buildings.
Do you think this is pretty much what you are looking for?
03 Mar 2009 10:56 AM
For my friends who wanted our info on the impact test.
Test performed by: Hurricane Test Laboratory Inc, Missile impact & cyclic load test, Three test performed, #HTL98072 Cert.#98-0127.02
I also have all the reports for: ICC, 1 & 2 Hr fire ratting, energy star, and UL.
email me for a copy of the reports, much too long to try and post here!
Kwik-Build Panels
03 Mar 2009 11:31 AM
Posted By Haddock@Thermasave on 03/03/2009 9:28 AM
Haddock;
aren't your splines, top& botom plates wood?
People Online People Online: Visitors Visitors: 185 Members Members: 0 Total Total: 185
