Posted By greentree on 02/23/2009 8:23 PM
Anything special an electrician needs to do when wiring an exterior steel sip? Bushing to protect the NM as it exits the steel skin or are the steel sips with steel stud interior partitions all conduit jobs? Just curious.
work is done with the same methods as using steel studs, exterior work is fed from the backside thru the furred interior
and romex may be used
