floating SIP house
Last Post 19 May 2009 06:36 AM by jonr. 9 Replies.
mmacgowaUser is Offline
05 Apr 2009 10:11 PM
I would like to consider a project doing a SIP house on the water. I am wondering if anyone has done anything like this?? I imagine a steel SIP would provide a great opportunity for providing a solid foundation for building a floating home.
I live in a resrot near a constant level lake in Texas. The lake is not very large and since it is a constant level my thought was to make a proposal for building a dozen barge condos that could be barged to one end of the lake or the other.
Any ideas??
06 Apr 2009 05:34 AM
They are Ideal for light weight, rot and mold resistant.
We are currently working with a developer for a similar type project in LA.
anddesUser is Offline
06 Apr 2009 05:34 PM
A SIP house on water would not be too difficult. Your 'barge' part will need to hold sewage, fresh water, fuel(?) and ????. Once you have determined the barge part then a SIP structure on top would be pretty straightforward. You could have a lot of fun with the design and even make a 2-storey structure, if it didn't look out of place. Good luck.
ErgoDeskUser is Offline
06 Apr 2009 06:58 PM
DeDutch
Attachment: medium_2250041061_fd244038a4_o.jpg
Attachment: medium_2250041503_a331b3787a_o.jpg
10 Apr 2009 05:24 PM
PS, you ca buy Steel Sips from:http://mansonvilleplastics.com/sips.htm
adalrympleUser is Offline
18 May 2009 07:36 PM
I helped a friend build a boathouse on Lake Union in Seattle, WA. If we had known more about SIPS we would have built with them. Weight was an issue. Email me if I can assist you with your project. [email protected]
18 May 2009 07:51 PM
It might be easier to drive down pilings. Then you don't have to worry about "this is a boat or a house" from the regulators. But sips make sense.
lambabbeyUser is Offline
18 May 2009 08:16 PM
mmacgowa:
The architect I used to help me design my own place--Russell Hamlet--designed a great floating house like you describe for one of his clients in the NW.    He's a gifted architect and may be worth consideration for your project.    You'll find pics of the particular house on his firm's website:   www.studiohamlet.com.     If you click on 'featured projects,' you'll find this particular house in the upper RH corner.    He's got about a dozen photos of it, inside and out.    There are also a couple of pics of it on the flash page that loads in as soon as you go to the website.
By the way, he's near Seattle and I'm in Maine, and it has posed no problems.     So don't let his location be an obstacle.
John
John A Gasbarre<br>Lamb Abbey Orchards<br>Union, ME 04862<br>[email protected]<br>
18 May 2009 08:40 PM
Pilings are a great idea but float/boat houses are great because you can move them. Lots of time location is a consideration and most times mooring your float/boat house is an issue and often the moorage is on a lease from whoever owns the dirt under the water where you want your home to be. Unless you own the dirt under the water then pilings don't work. Alternatively, geo-blocks have been considered to "anchor" to. The whole weight thing comes back to how much movement you can live with. Think of a sailboat, windage aloft makes it lean over. My friend added concrete as ballast to his "barge" hull to add stability. It was also "hard-chined" which makes the vessel more stable. All this being said, as long as the "vessel" has a running or slightly running motor (usually an outboard) and the correct navigational lights then you are legal. Don't forget, the beauty of building a houseboat is that, at least in Seattle, there are NO BUILDING PERMITS OR INSPECTIONS!! It's technically a boat.
Hmm, might be just the thing I need to deal with some swampy land and problems with regulators that I have.
Letting it swing on a mooring and face into the wind should help some with leaning.
People Online People Online: Visitors Visitors: 159 Members Members: 0 Total Total: 159
