Steve.
As per an earlier response. Labour cost is contigent upon the complexity of job, and whether the panels are pre-cut.
If you are using blank 4x panels and you an experience SIP installer, you should be able quote at standard local framing rates. In fact, you would probably be ahead dollar wise. Experience is the key.
www.phoenixbuilding.ca
