99betaalp
| 08 Jan 2011 12:14 AM |
I asked for a quote 3 weeks ago via email from their web site with no response. I called Sips Supply and someone answered that didn't seem interested in my business but said they would send me the information, it never happened.
Thanks |
cmkavala
99betaalp
| 08 Jan 2011 09:31 PM |
This one is Sips Supply in Atlanta. Here is their web site http://www.sipsupply.com/. Anyone done business with them? Thanks |
cmkavala
| 08 Jan 2011 10:13 PM |
Posted By 99betaalp on 08 Jan 2011 09:31 PM This one is Sips Supply in Atlanta. Here is their web site http://www.sipsupply.com/. Anyone done business with them?
Thanks according to the Georgia department on Corporations they are disolved http://corp.sos.state.ga.us/corp/soskb/Corp.asp?1224112 as of 9/12/2010 |
99betaalp
| 08 Jan 2011 11:52 PM |
Chris, Thank you very much for the information! I am wanting to build 1,900 sq. ft. in Colorado. Will look at your web site. Randy |
99betaalp
cmkavala
| 09 Jan 2011 07:14 AM |
Randy;
send a message to [email protected] and information that is not availble on the website will be sent to you |
Brian Propp
| 11 Jan 2011 04:46 PM |
Dear "99betaalp": ICS SIPs manufactures polyurethane SIPs in Fort Collins, Colorado. Please call us at (970) 282-7477. Thank you. Brian www.ICS-RM.com |
Dick Mills
| 11 Jan 2011 07:08 PM |
Brian, doesn't Murus have the patent on using cam-locks embedded in PU SIPs? Has their patent lapsed? Or are you licensing their technology? Maybe you are reselling their manufactured panels? |
Brian Propp
| 11 Jan 2011 09:13 PM |
Hello, Dick. You asked: Brian, doesn't Murus have the patent on using cam-locks embedded in PU SIPs? Has their patent lapsed? Or are you licensing their technology? Maybe you are reselling their manufactured panels? No. Murus has patent USD349235 (1994, expired 2008), which is for a specific plastic cam-lock design. ICS SIPs operates under patent 6564521 (2003) for panels, and patent 3784240 (1974) for steel cam-locks. Brian www.ICS-RM.com |
99betaalp
| 11 Jan 2011 10:58 PM |
Hi Brian, Thanks for the information. Just started looking at my options for building (1,700 sq ft) on my lot in Lake City, CO. Need some one to get me to the dry in stage. PM me with some of your thoughts. Thanks, 99betaalp |
Brian Propp
| 11 Jan 2011 11:11 PM |
Great. Let's take this off-line. Please call me at (970) 282-7477 and we can discuss your project in detail. Thank you! Brian Brian "at" ICS-RM "dot" com |
Dick Mills
| 12 Jan 2011 04:19 PM |
Brian, maybe I was mistaken in believing that patent 5743056 was a Murus patent. My only reason for believing that it was is that they referenced a Murus product brochure as prior art. But if I hear you right, you are saying that the only real difference in you patent is that you have those metal stiffened grooves and the fact that you are using a metal cam-lock instead of a plastic one?? What do you use as the top and bottom connections for your panels? Do the panels get fastened into metal tracks? or what? |
Brian Propp
| 21 Jan 2011 12:54 AM |
Typically, ICS SIPs have a 1-1/2" void in the bottom and in the top. Typically, 2x material is used as a sill-plate and as a top-plate. The panel skins are nailed to the sill-plate. Various other materials can be used as a sill-plate, such as plastic lumber, metal C-channel, etc. |
Lumbertakeoff
| 31 Jul 2015 08:55 AM |
We did some work for them  |
