Posted By cmkavala on 27 Jan 2012 07:39 AM
ICFs are seceptable to termite infestation
Yes, termites can eat the EPS but there is not nutritional content to it, as they are looking for wood, that is the only reason they would tunnel through EPS. But the big picture here is that even if they did eat the EPS, the structures strength remains intact, as ICF gets its strength from the 6" of concrete, not the EPS.
With SIPs, the termites would eat the wood OSB panels and eat the EPS, this will cause the SIP to lose strength over time and will cause structural failure of the SIP if not caught in time.
If the SIP is wood, termites will eat OSB panels and tunnel through the EPS sandwhich, which will cause the SIP to fail. This is not possible with ICF.
Now, with a steel SIP, the termites can still tunnel through the EPS inside but the steel panels will remain intact.
In regards to the problem the one homeowner was having, rodents ate through the OSB skin and started to tunnel through the EPS in the SIP. Once the EPS is gone, the SIP will fail structurally.
