SIP ice fish house
Last Post 29 Jan 2012 12:13 PM by cmkavala. 9 Replies.
24 Jan 2012 08:19 PM
I want a SIP fish house. Light and strong enough for loading and unloading from a trailer. It would also be on skids, for dragging on the ice. Besides being light the floor should have a good walking surface and decay resistant, osb would not be a good choice. The walls and roof should have an outer skin that would require little if anything additional to be weather proof. The inside skin should require little if any additional finishing. Attachment points are needed for bunks, cabinets, shelves and so on. Ideas?
TorbenUser is Offline
24 Jan 2012 09:53 PM
Yes, get some cheap metal SIP B-panels and whack together a fish house. Just don't stray too far from it. Against the snow it would be very easy to lose.
26 Jan 2012 07:06 AM
we have a lot of 3" steel sips left over from a job, but theres no ice fishing going on around us
27 Jan 2012 08:22 PM
How would steel sips work for a floor? How would I deal with the seams?
27 Jan 2012 08:52 PM
Posted By ICFconstruction on 27 Jan 2012 08:22 PM
We use them for floors when appropriate, not sure what you mean about the seams?
27 Jan 2012 09:06 PM
12" Steel SIPs floor spanning 22 ft.>
8" Steel SIPs floor spanning 13 ft.>
.............4" Steel SIP loft floor spanning 9 ft..............
27 Jan 2012 09:23 PM
Do you just seal where the SIPs connect? when is it appropriate to use for a floor? I don't want to cover any surface, except maybe the floor with truck bed liner.
27 Jan 2012 10:08 PM
You would not need to cover it with anything, but a rubber mat would help the surface from getting dented by sharp objects.>
I have an air conditioned storage loft over 1/3 my garage using 4" x 7 ft. steel sips, I use it mostly to store old business files, I just cleaned out 8 years worth of old files today
ICFHybridUser is Offline
29 Jan 2012 10:31 AM
Since SIPS are so flexible, once you are done with the project, you should cut the edges and paint it to look like it was put together with giant LEGO building blocks. That company might even have marketing funds to defray the cost of construction for you.
Unless you were thinking about something in a French Provincial fish shack, that is. :-)
Florida fishing for ICE house ...................
People Online People Online: Visitors Visitors: 161 Members Members: 0 Total Total: 161
