SIP Picnic Shelter
Last Post 04 Feb 2013 06:44 AM by cmkavala. 13 Replies.
Author Messages Informative
31 Oct 2012 05:45 PM
This 1600 sq. ft. picnic shelter, built by Hope United Methodist Church - Trinity, FL. with all volunteer labor. Designed to withstand 140 MPH winds. although 4" roof panels would have been sufficient, 6" were chosen to muffle rain noise.
rnortmanUser is Offline
31 Oct 2012 06:53 PM
I don't mean to offend -- that's a nice-looking structure -- but it doesn't seem like a natural application for SIPs.  What was the motivation for them to choose SIPs for this project?  I'm sure you could also achieve the same wind resistance with more conventional rafters or trusses.
31 Oct 2012 08:33 PM
Posted By rnortman on 31 Oct 2012 06:53 PM
Rnortman;
No offense taken, yes it could be accomplished with wood trusses.
but it is actually an ideal application for a low maintenance pre-finished panel, insulated to shade from the oppressive heat, was able to be installed by unskilled church volunteers off of step ladders,
No crane required
31 Oct 2012 11:48 PM
Posted By cmkavala on 31 Oct 2012 08:33 PM
Rnortman;
No crane required
With the steel SIPs there is no wood to deal with, that is another advantage. Exposed wood trusses are a constant maintenance issue.
How did they run the electrical conduit for the lighting?
johnmessiUser is Offline
01 Nov 2012 03:34 AM
You have shared really informative and interesting post i will like to say thanks and also request you to keep post that kind of stuff in your more posts.
<a href="http://epdmcoatings.info">Liquid Roof</a>
01 Nov 2012 07:29 AM
Posted By Lbear on 31 Oct 2012 11:48 PM
Rnortman;
No crane required
I see structures like that often built with a metal structural frame clad with standing seam metal roofing.  Looks real nice.  But I think the main selling point in this case would be the unskilled volunteers, who would not be able to assemble that kind of metal frame reliably in a reasonable amount of time.  So you'd have to do wood, so you'd then have all the problems of wood.  The simplicity of SIPs, particularly pre-finished, is the winning feature here, it seems to me.
01 Nov 2012 05:00 PM
Rnortman;
No crane required
Lbear;
the panels have a vertical chase to conceal armored cable.
the wire feeds for the ceiling fans are run thru the hollow box beams
all are concealed under the ridge cap
01 Nov 2012 09:15 PM
Posted By cmkavala on 01 Nov 2012 05:00 PM
Lbear;
Do they offer 2LB EPS instead of 1LB EPS?
01 Nov 2012 09:48 PM
Posted By Lbear on 01 Nov 2012 09:15 PM
Lbear;
..........Yes
SimonDUser is Offline
04 Nov 2012 04:40 PM
Hi Chris,
Nice project. Were the posts sunk into the footing or some sort of baseplates used?
Building Designer PANELfusion, LLC Tampa, FL [email protected] "Metal SIP Advocate"
04 Nov 2012 08:54 PM
Posted By SimonD on 04 Nov 2012 04:40 PM
Hi Chris,
Post are set into 2 ft x 2 ft. x 4 ft conc footing with 2 - #5 rebar crossed thru posts
03 Feb 2013 09:35 PM
new pic
03 Feb 2013 11:43 PM
Nice to see people using the area in sunny Florida.
During a hurricane, are there any extra tie downs that have to be used or is it able to withstand the 140 MPH winds as is? It would seem as though the uplift forces on those panels would be quite intense.
Posted By Lbear on 03 Feb 2013 11:43 PM
Lbear,
recently built at my own church in Trinity, FL. with all volunteer labor, was designed for 150 mph
People Online People Online: Visitors Visitors: 183 Members Members: 0 Total Total: 183
