U.S. manufactured MgO panels
Last Post 03 Aug 2015 08:35 AM by cmkavala. 4 Replies.
ckrug03User is Offline
03 Dec 2012 11:49 AM
I have been looking into having a home built uing MgO SIPS. After a year of research I have looked into the benefits of using MgO over OSB. It seems like a no brainer besides the fact that all MgO is imported from China. Does anyone know of a supplier of U.S. manufactured MgO SIPS panels?Thanks in advance.
EnergyWiseBuildingUser is Offline
29 Dec 2012 09:19 AM
Extreme Panel in MN 800-977-2635 has built MgO SIPs for me. Just got some. Talk to Terry, they do nice work.
http://www.extremepanel.com/
We participated in a whole house MgO SIP house, even below grade, they worked well only the panels were poorly made from someone else using urethane insulation. Stick with EPS and talk to Terry.
InnovaUser is Offline
25 Feb 2013 07:46 AM
We manufacture MGO SIPS panels in Miami Florida. Please check our webiste, Innova Eco Building System.
vh2qUser is Offline
02 Aug 2015 05:32 PM
Posted By Innova on 25 Feb 2013 07:46 AM
I can confirm that they manufacture these MGO panels in Miami. We paid $55K for exterior wall and roof SIPS for a 1750ft2 3 bed 3 bath house we built in Bahamas. The problem arises when you try to put their panels together: the majority of the panels we received had major dimensional problems. For example, our roof design required hips on both levels on the South end. Innova manufactured the panels to fit together laying flat on the floor in 2D. See photos. When erected in 3D the apex angles were naturally all wrong. We had to recut every pie-shaped panel in the field and we had to cut the correct compound angles along the hips (Innova cut them at 90 degrees to the face). Hard to get a clean seam in the field so we had to use wood trim to conceal some of the seams on the underside. While all this cutting and fitting was going on we were paying for a crane and rental on two containers, plus a crew of five. When we raised the issue with Innova they blustered, blamed our contractor, then they blamed me for not checking the panels at the factory, then they ran and hid behind their fine print. They also managed to cut two wall elevations (gable ends) 3" too tall. Same bluster and blame. And every window opening was cut to the size of the flange not the "daylight opening" dimension specified in the mfg specs I sent them with a stern admonition to pay close attention to the specs to avoid the very disaster that ensued, not to mention they had the windows in hand when they cut the panels. We had to fur out every window opening causing complications with waterproofing. They forgot to ship window angle brackets, the lost my a/c brackets, they short shipped loose MGO sheets for the exterior wet walls, SIP screws, caulk and the special joint compound they recommend. The only things they shipped in excess were coraflex stucco and grailcoat for a deck ... both of which I paid extra for. It took over 5 weeks just to get the panels up. I calculated their errors and omissions (excluding the shortages) cost us over $10K in additional labor and equipment rental.
vh2q,
reasons I never liked pre cutting panels in the factory, even if they don't make a mistake , there is no forgiveness for a changed field conditions
