Metal SIP exterior finishing
Last Post 19 Feb 2013 09:21 PM by cmkavala. 28 Replies.
BrianUser is Offline
16 Feb 2013 03:31 PM
I think i like a plumb cut, that looks like a good place for wasps to build in
$50/hr if I do it, $75/hr if you watch, $100/hr if you help!
16 Feb 2013 07:42 PM
Posted By cmkavala on 16 Feb 2013 07:38 AM
Lbear,
It is hard to improve on a prefinished product that already looks like a soffit
even this 1.3 million dollar home left the white 26 ga.steel skin exposed
the panels come with a matching fascia cover
A flashing detail, if any ,would be job specific, depending on the method of attachment to the wall
I thought where the 2 panels lock needed to be waterproofed on exterior portions. It's a T&G connection, right? Would that be air/water tight on a 24" exposed soffit?
The matching fascia cover is simply just screwed into the SIP on the top and bottom?
16 Feb 2013 08:57 PM
Fascia cover detail.........................................
17 Feb 2013 03:02 AM
Posted By cmkavala on 16 Feb 2013 08:57 PM
thanks of the detail!
Are the weep holes factory installed or is it done in the field?
Ideally shouldn't the roofing material extend over the top of the facia cover to give it water protection?
Can you get a SIP with the facia covered with a factory laminated 26 gauge steel?
17 Feb 2013 07:33 AM
Posted By Lbear on 17 Feb 2013 03:02 AM
in field
yes and the finished roofing would, ir the panel is left exposed, then"optional " sealant is applied
No
19 Feb 2013 03:04 PM
Do you recommend taping where the panels join with SIP tape?
19 Feb 2013 04:47 PM
Posted By Lbear on 19 Feb 2013 03:04 PM
Only if you are leaving panels exposed
If you are you using self stick under the standing seam, then you have taped it
19 Feb 2013 05:04 PM
Posted By cmkavala on 19 Feb 2013 04:47 PM
What about the underside of a soffit? What kind of SIP tape, would OSB SIP tape work for metal?
No, if you want the underside sealed just caulk the narrow joint with white latex elastomeric caulk.
People Online People Online: Visitors Visitors: 169 Members Members: 0 Total Total: 169
