Roofing and Metal Sips?
Last Post 15 Feb 2013 07:39 AM by cmkavala. 12 Replies.
BrianUser is Offline
12 Feb 2013 09:52 PM
What are my options when finishing the roof when using M-SIPs? I talked to a few roofing guys at a H&G show this week and they where clueless. Metal sips are not common up here so no one really has much experience with it. Im up in Colorado by the way. Ideally we would like to use comp roofing as it fits in with most the roofs around here. Standing seam is nice but not always a good fit in some neighborhoods.
$50/hr if I do it, $75/hr if you watch, $100/hr if you help!
13 Feb 2013 10:14 AM
Posted By Brian on 12 Feb 2013 09:52 PM
Brian,
all attachments roofing or siding are with screws, or adhesive (in the case of peel n stick underlayments or attaching cement barrel tiles to underlayment)
13 Feb 2013 11:00 AM
Asphalt shingles,.........................................
travisbrichUser is Offline
13 Feb 2013 01:19 PM
Roofing felt not required?
14 Feb 2013 04:37 AM
Posted By travisbrich on 13 Feb 2013 01:19 PM
travisbirch,
If the roof is simple , The metal SIPs are already water tight,then the shingles are only applied for cosmetic reasons and felt is not required.
If the roof is more complicated with valleys,etc.
then felt is required,
14 Feb 2013 08:44 PM
In my opinion, if the roof deck is penatrated by fasteners best practice is to use felt or a peal and stick membrane. Even with metal SIPs. Composite Shingles can also be glue applied. then a membrane is not necessary over metal SIPs.
14 Feb 2013 08:55 PM
Here's a detail.
14 Feb 2013 09:45 PM
Posted By JeffD on 14 Feb 2013 08:55 PM
Here's a detail.
JeffD,
In theory this works, but from a practical point
How does one glue it and then walk accross it, It would be sliding all over the place?
14 Feb 2013 10:51 PM
I agree, gluing it is a formula for nothing good and a lot of pain and time.
I don't mind putting ice and water shield on the entire roof. We are not looking at the metal roofing that looks like comp. 50 yr roof with a classic look
15 Feb 2013 04:15 AM
So when installing a standing seam metal roof onto a metal SIP, would one have to screw down the one layer of 30 lb felt and then screw the standing seam metal roof onto the metal SIP? Roofing underlayments are usually nailed down and then they come back and install the roofing material, be it asphalt shingles, standing seam or whatever.
Is using a roofing material like VersaShield which is a UL Class A rating roofing underlayment a good idea on a steel SIP roof or is it overkill? I can't find if VersShield is approved to apply onto a metal substrate like that of a steel SIP. It just lists OSB/plywood.
15 Feb 2013 04:35 AM
Posted By cmkavala on 13 Feb 2013 11:00 AM
What is the spacing on the SIP screws, are they at 12" oc?
Do you have any install pics of a standing seam metal roof?
On a standing seam metal roof most roofers are use to screwing into OSB. How and what type of screw do they have to use for a steel SIP to prevent it from stripping out?
15 Feb 2013 07:29 AM
Posted By Lbear on 15 Feb 2013 04:35 AM
Lbear,
It appears in this picture the spacing is 12" , but spacing may vary from 6" - 12" depending on the engineering requirement for uplift
on standing seam roofs a #8 or #10 sharp point screw is used in both OSB and steel skins
the screw used to hold the asphalt shingle is a #8 x 9/16" wafer head screw, the head is the same size as a roofing nail
Posted By Lbear on 15 Feb 2013 04:15 AM
Lbear,
we have actually nailed the felt with ring shanked simplex nails or used tin tabs with screws,
I think the VersaShield is better suited for wood,
we prefer Polystick MTS over all underlayments
People Online People Online: Visitors Visitors: 499 Members Members: 0 Total Total: 499
