Curved Metal Skin SIPs?
Last Post 16 Dec 2014 02:43 AM by englert123. 8 Replies.
26 Aug 2013 02:51 PM
Are there manufacturers in the US that produce curved, metal skin SIPs with a specified radius for walls and roofs?  If you know of any, please furnish web address.
10 Sep 2013 07:19 AM
Posted By Alton on 26 Aug 2013 02:51 PM
Alton,
I have been in it for nearly 20 years and while they can be built in a plant, it is a very expensive endevour with no market demand.
It can be accomplished by the installer in the field
10 Sep 2013 11:49 AM
Two sheets of sheet steel bent to the proper shape, tied together with bolts and then filled with pour-in two part foam might work. Boat builders often use this to fill cavities.
10 Sep 2013 12:48 PM
Posted By jonr on 10 Sep 2013 11:49 AM
Two sheets of steel bent to the proper shape, tied together with bolts and then filled with two part foam might work.
One builder suggested this same idea for the roof but mentioned using a jig instead of bolts to properly space the skins.  My concern about this method is that it will take someone with experience working with two part polyurethane to assure quality for the life of the roof.  Pouring urethane is quite different from spraying it.
I talked to a sprayfoam contractor about spraying foam between two skins for a continuous wall.  It probably could be done but there would be no assurance that the foam would be consistent (without voids).
I like Chris Kavala's method for making a curved wall but will the kerfs weaken the panel too much if used for the structure of a roof?
10 Sep 2013 09:35 PM
Alton,
Monocoque : is a structural approach that supports loads through an object's external skin, similar to a pingpong ball or egg shell. The term is also used to indicate a form of vehicle construction in which the skin provides the main structural support, The technique may also be called structural skin or stressed skin.
The kerfs are reattached with new skin materials – stitch screwed together, with the exterior curvature , it may be stronger than the original flat SIP
10 Sep 2013 10:46 PM
Thanks for the explanation.
englert123User is Offline
15 Dec 2014 02:07 AM
Curved panel roof system design is one of the important task which can be not done accurately can affect the strength of the building. There are many manufacturers in US who can manufacture these types of metal roofing.
15 Dec 2014 02:32 AM
Posted By englert123 on 15 Dec 2014 02:07 AM
Englert123, these are not SIPs , they are simply curved standing seam panels
Metal roofing depends on the metal type as different metals has different properties, so it affects the design and curve design of the metal. One should get to know about these and after that he can apply it either in building or some other way.
People Online People Online: Visitors Visitors: 213 Members Members: 0 Total Total: 213
