Posted By gwiz on 07 Jan 2014 02:50 PM
Good day all.
The shop I work in is looking to replace its roof (when it warms up). Right now the roof is steel ribbed panels with fiberglass insulation underneath it. The building is about 60 years old and the roof is almost 30 years old and has some leaking issues around the edges. The support structure is iron main beams 20' apart with smaller cross beams every 4-5'. Building is 50' x 100'. I have suggested using sips when the roof is replaced to increase the insulation value and stop the issues of condensation and leaking due to ice dams. It is a tapered roof and we are located in mid Michigan. Is there a general number on cost per sqft?
What do you think. I believe it is doable but does anyone have an experience with this type of retrofit? Any installer recommendations?
Thanks for all your thoughts.
Regards,
gwiz,
yes it is for new construction as well as retrofits over red-iron frame, panels are available in thicknesses 2" to 12" x 46" wide and upto 53 ft. long
