Posted By eric anderson on 03 Mar 2014 07:36 PM
Are there Steel sip suppliers/ installers in the north east, specifically Connecticut?
I am looking for options for replacing 2 roof sections. Both sections are about 18x56 ft and are exposed rafter roofs ~ 1.5/12 pitch. Rafters are 4x8 Douglas fir 32” oc. The exposed underside of the roof would need to be white. I am suggesting a steel sip may be the easiest/fastest way to do it. The current roof decking is 2 ½” Homosote roofing panels~ 40 years old. There are several areas of water damage and some panels need replacing anyway, so adding insulation over the homosote does not make much sense. Basically there are massive ice dams every year due to poor insulation value of the Homosote panels.
In my mind, the alternative would be 1.5” Cedar roof decking + 2 layers of 3” iso and sheathing over the top of that, if we don’t go the sip route.
Eric
Eric,
Most steel SIP suppliers are in the southeast US contact :
www.PermaTherm.net PermaTherm recently supplied a steel SIP over timber frame @46" oc to an owner-builder in Pine Island, FL. , The project can be viewed at
www.PermaThermSips.com the owner installed the panels in just one day
