Structural Insulated Panels (SIPs)
Ice and Water Shield on SIPs
Last Post 01 Feb 2017 03:53 PM by
EdW
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
EdW
31 Jan 2017 02:31 PM
Should ice and water shield be placed along the bottom 2-3 feet of roof SIPs. There will be a cold roof over the SIPs. I'll also have a very small shed roof (12' x 14') over a laundry room bump-out. I can't vent it since it comes off the side of the house. Should I put ice and water shield on that? Thanks.
cmkavala
31 Jan 2017 10:56 PM
it can be vented with an "off ridge vent"
Chris Kavala<br>
[email protected]
<br>1-877-321-SIPS<br />
DavidBrownEnterprises
01 Feb 2017 09:27 AM
Why would you need an ice or water shield for a SIPS roof? Also, why would you want to "off ridge vent" a SIPS roof?
3cityblue
01 Feb 2017 10:17 AM
The OP might want to expand on his concerns. Certainly using ice and water shield on the SIP panels below the cold roof will not hurt; but it might not be necessary. Since the SIP panel surface should be cold in any case, the 2'-3' bottom portion would not be prone to ice dams which is usually the reason for that application. The key to avoiding problems at the SIP outer surface is to make sure the interior SIP surface/joints are well sealed to prevent warm moist air escaping to that cold outer surface.
I assume the venting question is related to the cold roof; and a off ridge vent could provide the necessary venting for your little bump out.
EdW
Yes, it is the potential for ice dams that is the concern. With respect to the small shed roof, it is a 4:12 pitch so I'm concerned about snow sitting on it for a longer period than with a roof with a greater pitch. I was not aware of the option for off ridge vent.
Membership:
croccohvacusa
People Online:
