SIPs - What should I know?
Last Post 19 Jul 2022 11:51 PM by cmkavala. 5 Replies.
rp_hoUser is Offline
13 Feb 2022 09:58 AM
We're looking to build a new home, and have been talking to builders. One of the builders is doing a standard build - Brick veneer on a timber frame, can't guarantee air tightness. But overall they seem reasonably high quality. The other builder uses SIPS panels and can (for extra money) get PassiveHaus certification. Obviously, we're quite keen on the latter, pending budget. While we're working that out, I wanted to find out if there any gotchas for SIP panels, or things that would make me stretch my budget to go for the SIPs build. These are my current assumptions, correct me if any are wrong 1. SIPS will result in a better air tightness by default 2. SIPS will result in equivalent, better insulation, than a well insulated brick veneer construction. 3. For SIPS, its difficult to expand on (changing electrical, plumbing, add-on rooms), so its important to get it right straight off. Also heard some things I'm not sure of 1. There can be issues with roof failures in cold climates (?)_ if the builder doesn't take care of the details correctly. Is this something to worry about in a relatively temperate climate? 2. What materials are typically used for cladding, and internal walls? 3. Is there any difficult wall mounting things? Internally or externally?
13 Feb 2022 03:14 PM
The answers to your questions may depend upon the type of SIP you plan to use. For example: OSB with Expanded Polystyrene (EPS) cores? Or, metal skins with polyurethane (PUR) cores? Etc. See this site for more details about types of SIPs: https://www.constrofacilitator.com/advantages-and-types-of-structural-insulated-panels/
13 Feb 2022 10:13 PM
They're using OSB with EPS cores (Neopor). Another question I had was around sound - Apparently sound insulation is poor with SIPS?
07 Jul 2022 10:37 AM
Posted By rp_ho on 13 Feb 2022 10:13 PM
rp ho,
SIPs are excellent for mitigating high frequency STC , but not so good for low frequency
for this reason it's good to fur-out the wall (airspace) and then apply drywall
newbostonconstUser is Offline
08 Jul 2022 12:29 PM
Sound is passively reduced by the energy being absorbed by mass. Anything that adds mass. I don't see how adding air space will do anything in the research I have done.
Same reason insulates glass air space mitigates sound transmision
People Online People Online: Visitors Visitors: 581 Members Members: 0 Total Total: 581
