- Check with your structural engineer before you put insulation under the topping layer on Spancrete. Sometimes the 2-3" topping is counted as part of the concrete design. It's probably won't affect you, but it's worth checking on first.
- Using rebar in place of wire mesh in might not meet ACI standard for minimum concrete cover distance.
- Regarding the high thermal mass, we had some good discussions here:
http://www.greenbuildingtalk.com/Forums/tabid/53/forumid/12/postid/70675/view/topic/Default.aspxHope that helps...
