Suggestions for Installing KWH Monitoring Items
Last Post 19 Sep 2011 08:53 PM by a0128958. 21 Replies.
morecode
| 19 Sep 2011 07:57 PM |
Bill, I visited your welserver site and saw the pictures above but I'm still a little confused on hooking up my wattnode meter to measure my geo system. I want to get my welserver up this coming weekend. I bought the Wattnode meter with the P3 option and I understand the ct's, but the hooking up the power for the device is a little confusing. It says I should choose a 5-20 amp circuit to power, yet in the diagram it shows the ct's on the same wire as the input side which in my case is 2 wire, 70 amp breaker for the Climatemaster WTA heatpump. Do I just need to make sure it's on the same "phase" or should I actually attach it to the 70 amp breaker? Can you clarify this? Also I would be interested in your assistance with the welserver computations to use just one of the P3 circuits to measure 240v, as I saw your post on this subject in another thread.... that way I could monitor the well water pump and the circ pumps separately with the other p2, p3 lines. My climatemaster uses 6-2 wire and the grufundos pumps use 14-2 and my well pump uses 12-2 (all 240 volts). Do I understand I can measure (accurately) 3 240v circuits with the P3 option??? Your wisdom and experience is apprecitated! Mike |
Bill Neukranz
| 19 Sep 2011 08:53 PM |
Mike, I started a new thread for you so as to not dilute this thread, and to give you the 'freshness' of a new thread. My comments are in the new thread.
Bill |
174 |
174 |
