rgonyer
| 24 Oct 2016 10:27 AM |
Footings are poured! Things are moving now. Builder promised to caulk underneath the framed walls, and the OSB to the studs. Seems like a good start. |
rgonyer
| 24 Oct 2016 11:03 AM |
[URL=http://s346.photobucket.com/user/rgonyer/media/New%20House%202016/10-20-2016-1_zpssboj8glr.jpg.html]  [/URL] |
rgonyer
| 11 Nov 2016 11:39 AM |
Posted By BadgerBoilerMN on 04 Oct 2016 11:02 AM
This is the standard in N. America for sub-slab insulation. http://www.menards.com/main/building-materials/insulation/insulation-panels/f250-2-x-4-x-8-r-10-extruded-polystyrene-insulation/p-1444450504310-c-5779.htm?tid=-9197785561416543961
Anyone else have any suggestions for underslab? This stuff is almost a buck a sq. ft. Would love to find something lower cost if possible. I've been trying to find used/reclaimed without any luck so far, but I need to get it pretty soon. |
Bob I
| 11 Nov 2016 11:43 AM |
We buy EPS for less than half that. Look at commercial roofing outlets like ABC, Beacon Sales etc. |
| 11 Nov 2016 11:54 AM |
Posted By rgonyer on 24 Oct 2016 11:03 AM
That is a LOT of corners & bump-outs, which will increase your framing fraction to well over 25%, maybe even more than 30%. that makes it harder to air seal too, especially at the non-perpendicular corners.
The high framing fraction would make exterior foam an even more signficant performance improvement than on a house with 8 or fewer corners (A "T" topology or simpler.) |
Bob I
| 11 Nov 2016 11:57 AM |
Coming together - Great! |
TWhite
| 17 Nov 2016 10:49 AM |
I would use sill seal under your bottom plate instead of caulk. |
Bob I
| 17 Nov 2016 10:53 AM |
foam sill seal is junk; it does not seal. Use these EDPM construction gaskets, which run about $1/lf: http://www.conservationtechnology.com/building_gaskets.html
drewintoledo
| 02 Dec 2016 09:23 PM |
Instead of caulking the sheathing, you might enjoy a product such as "ecoseal" which is applied within the inside of the stud bays and along the sill plates with a high pressure airless sprayer. If you search youtube for "ecoseal", you will find demonstrations on how it penetrates into the cracks. If you're persistent about using a caulking product, I've learned from the chatter on this board and GBA that you should be sure to use a high quality polyurethane caulk and not your typical paint-on low quality caulk. I am enjoying this thread as I will be building next year or the year following. |
| 03 Dec 2016 05:01 PM |
I wonder how many people using caulk/sealant even know what "3 sided adhesion" is or why a bond breaker is necessary in a fillet joint. |
greentree
| 04 Dec 2016 09:58 AM |
Maybe 1 in 20, and of those, myself included, half or better ignore those rules most of the time. You really gonna make a tiny bond break at a floor to tub intersection? Backer rod is at least easy, corner bond break not so much in smaller residential joints. |
crabapple
| 28 Jan 2017 02:25 PM |
http://www.conservationtechnology.com/ It worked for me & I cut & pasted it. |
crabapple
