Myrtleboone:
It's been awhile since that original post and I'm just now getting around to
breaking ground this coming Fall for the new place. The downturn in the economy forced me to postpone things a bit. The house
design shifted significantly over this time too, but I'm still going with a small home (1,214 sq ft) with super-insulated walls
and triple-glazed windows. Specifically, I'll be using some very
cost-effective passive house windows made by a company in Lithuania and being
sold in the US through a number of distributors. The window
company is called Intus Windows and the local rep in Maine that I'd
recommend is a great guy named Christian Corson. You'll find YouTube clips as well about these windows that will give you a good sense of them. Christian can be
contacted through his business ( Ecocor Design/Build ) either by calling him at (207) 930-5088
or e-mailing him at [email protected]. He knows his stuff and
is really passionate about what he does.
The overall building envelope I'm now going with will be a bit of a departure from my original plans. It'll now be constructed as follows:
Exterior walls (R-67) will be
comprised of a 2 x 4” load-bearing inner wall assembly filled with 3 ½” of
Roxul ComfortBatt insulation, plus outer 11-7/8” TJI 560’s filled with JM Spider blow-in
fiberglass insulation. OSB air barrier
will separate the sections within both roof and wall assemblies. Basement walls (interior and exterior) will be ARXX Prime ICFs over 8” concrete
slab and 12” of Foamular 600 XPS sub-slab insulation (R-65.) Roof (R-94) will be comprised of a 16”
TJI 560 cantilevered truss system filled with 16” of JM Spider fiberglass BIBS
beneath a 4 ½” layer of Hunter Panels H-Shield NB polyisocyanurate bonded to
OSB and topped with 5/8” of Advantech T&G Roof Sheathing.
Roofing will be McElroy Medallion-Lok Standing Seam Metal Roofing secured to
the Advantech through layers of Pro Clima Solitex Plus roof lining membrane and
Grace Ice & Water Shield. Siding will consist of 1x12" D & Better Select Kiln-Dried Eastern White Pine Reverse Board & Batten siding attached to perpendicular 1x4" furring strips over a Pro Clima Solitex Plus sarking membrane to form a rainscreen and watertight envelope.
The full scope of technical details
for the house can be found here.
Good luck with your project!
Litawyn
