Posted By BadgerBoilerMN on 18 Apr 2012 02:32 PM
If you want live in a cave maybe. If you have glass and passive solar gains, the controls get more elaborate, expensive and like thermal mass reach a point of diminishing returns. There are few absolutes in this world though the idea is ideal.
The more perfect the climate the less you need to mess with it.
interesting
but
is there a more definitive ROI/ or "greenness"
to clarify for the one with the original Q ?
Seems D1 is more cost effective in many (10+) years, but how much more or less can one be shown in dollars and the "leather" of lifestyle choices...?
There IS a lot of sense to some higher mass, as we bounce a zone 5.1/2 right in my county to 50-deg Jan always, to this winter GT Loops fired in COOLING MODE on the 80-deg days 2 weeks ago ( 37 this morning ).
I have noted on any air-conditioning without controls on 'condenser' conditions in cold to hot to cold jumping ambients, and risked popping compressors - residentially not generally having Head-Pressure controllers on GTHP, unless I T-in as for cold starts with HW and Radiant..
But too
the SEER (salesy eer) could have been near 40+ and over that making HW instantly on demand,with GT loop pumps off-line at that time and then back on for Air Cooling, the efficiency is very very much higher than any air-source, but not as high as a mass not needing intermittent cooling... yes/no ???
I mean all that the mass with gt loop swings can be a factor-
but what is a lees graphical answer to ROI and more than avoiding 'the mess'...?
ROI's then, est.
-would imagine some real "BEST MASS" could be Lifestle-Ambient-Avg-Computed (I saw some graphics, thanks..
I have a reference by customer:
The customer 5 ft under ground in 1600 sq ft 5-bay car wash building (similarity with extended side wall "trunk-halves" like trees are created at the curve) had a 2.0 GTHP and up-sized to a 30k (some 3.0 sizing) compressor on well water 52, cools like any 3-ton air unit, net to net...and runs it at a slow 340 cfm/ton for HRV effect and the spill-over goes int a back enclosed small POOL in ~ 20x30 half below grade. NO SUPPLEMENTAL HTG. has only DeSuperheat HW and elect HW his lowest bill with all minimal charges, is only $40 different than the highs...2010, so might be $50 diff. for highs, but he can INSTANTLY control dehumidification or swing heating, etc.
