Thanks for the help. I was beginning to think I was swimming up stream.
It's easy to beloeve that you can't or "don't need to internally vibrate ICF's. I have seen way to much evidence to the contrary. Even when you use a "soupy mix" and pea gravel. With a soupy mix and pea stone you get great amounts of segregation. I have seen it with my own eyes. Strip the bottom of the next ICF basement walls you do and look at the very bottom of the cncrete. That's a place that you typically may have segregation especially in the corners if you do not vibrate internally. That's a good place to start your learning curve.
