Posted By Nerotin on 31 Dec 2017 07:28 PM
RP Watkins. Is the best hanger. No ledger. No brackets there after. It’s all in one.
U make two insitions slide the bracket pour concrete drop the joist. Done.
I don’t see how using anchor bolts that won’t match 16oc and will end up in a way of a plastic insert that’s more difficult to drill and slide the bolt through. Might work if u do 24 or 12oc.
Then u have to lift this heavy 2x12 ledger and the. U still buy the brackets to hang the ijoist
At the end $$$$$ more time more bullshit
Where Rp Watkins as I recal cost $11 a bracket? Not sure. Insert and done. Drop ijoist later
Do cost analysis 5/8 anchor bolts I’ll asume $1.50 each double at 24oc
2x12 ledger board. Cost $2 a liner foot. Give or take
Hangers for i joist I’m thinking top mount at $7 each
By all means someone explain how rpwatkins is not an ideal best better cost effective way???????
I think that Anchor bolts are cheap and functional, but the extra time makes them less ideal (and not as cheap overall).
My biggest concern with RP Watkins hangers is that they must be placed at the perfect elevation, since you cannot adjust the joists after concrete is poured (you can shim/trim each joist, but then you are losing the speed/efficiency). This seems easy, but crazy things can happen when pouring concrete (blocks floating, shifting, etc). On paper, these are the ideal solution, but sometimes on site things are not ideal... just my 2 cents
