Thanks to every one for posting
Posted By FBBP on 04 Nov 2013 10:37 AM
Krom - you are right that it will draw heat out of the building but you need to consider a few more issues.
With a break right at the door, you significantly weaken the slab at a crucial point. The part in the door opening is on the stem wall and the part just inside is on fill and has the added vehicular weight. For sure it will shift at this point.
If you are sloping the floor to the door, any break will receive copious amount of (salt) water. This will enter the joint and cause problems over the years.
IMO you are wasting your money with mesh, especially if it is cheap rolled mesh from the box store. Use 3/8 or preferably 1/2" rebar @ 16" o/c b/w.
While you are loosing heat from a 5" slab, you are loosing more heat from the 6 to 8" core of the icf stem wall. Think of heat like water (well maybe maple syrup) It will run to the lower concentration and as concrete is very conductive, it runs quite quickly.
Possible solution. Use Smartwall's composite deck, which probably has grooves in the back, to give it a better seal and then run a couple of dovetail grooves in the from. This will help to seal out water. Drill the board 16" on center and run the rebar through to the stem wall. Yes, you will get some heat lose through the bar but that is what it is. If you want, price out some stainless for this section. Don't use epoxy coat.
Put a couple or 3 inch cap of eps (or window buck if your block supplier handles it) in the top of the core.
If you put the break right under the door, drop the finished level of the apron by 1/2 inch. This will prevent wind driven rain from backing up under the door and help inside water drain way quicker.
I was considering 5'x10' sheets of 6" mesh (its commonly used around here and makes it easy to lay radiant tubing with no tape measure needed)
My concern was drawing heat out of the 8" core of the building (as well as the floor slab), and trying to break both, yet have something that was strong enough to be driven over daily, and have lots of salt water running over it. I was assuming there was a proven method for this that I hadn't found yet.
Since I tend to over think things... I was trying to avoid building some sort of enormous concrete structure on its own footings to act as an apron, and have it cantilever over the stem wall to butt against the floor
I'm having a hard time picturing the bolded.. are you talking about using the composite decking as a threshold for the bottom of the door to seal against?
also when you say don't use epoxy coat, you mean epoxy coat rebar, or epoxy floor finish.
