Posted By sailawayrb on 06 Jan 2015 09:34 AM
Interesting Craigtoo, you managed to find the one issue with the program that I mentioned previously:
“The only issue that I am currently aware of that causes the program any grief is if the total conventional heat flow and the total thermal mass heat flow end up being contrary total heat flows (i.e., one is heat gain and the other is heat loss). When this happens, the program would calculate a negative effective R-value, which of course would not have any rational meaning. So if this happens, the program just reports the effective R-value as “Unknown” and one would have to take a close look at the hour-by-hour report-out to better understand this. BTW, I recently added hour-by-hour effective R-value report-outs to help folks better understand what is happening real time. These hour-by-hour effective R-value report-outs are NOT used for anything other than this increased understanding. Thus far, I have not found an outdoor temp profile that has caused this issue to occur.”
Presumably, both the total conventional heat flow and the total thermal mass heat flow are small and of opposite signs causing the program not to know what “goodness” is for this condition (i.e., is reduced heat gain or reduced heat loss “goodness”) and therefore unable to determine the effective R-value?
The best advice I could provide at this moment would be to use the conventional R-value when this "Unknown" situation occurs. I would also suggest that you use Weather Spark to create an actual daily outdoor temp profile for your location that perhaps might not have this issue.
Thanks Sail...!
I had read your post which you've referenced above.
I downloaded genuine temp data for my area and it worked well. Much more reasonable data. It appears that if you input wide outdoor temperature swings where the average of that swing is close to your desired indoor temperature target the situation with contrary heat flows appears. Which makes sense.
The use of more reasonable (and legitimate) data from WeatherSpark gave more meaningful results. "You can't make chicken salad out of chicken $^"
Now, can we change the green color to more of a Clemson Orange?
