ronmar - The Corbel Ledge would give me more meat for my I-Joists to sit on. The ledge, along with 2" reduction in form, should give enough load bearing concrete. I'd love to see a few pictures, from above, and from below. The idea sounds practical but I am wondering how a.) the corbel ledge looks on the interior of the basement and 2.) how you finish that basement wall. I would not be using 4x2 trusses...just standard 11-7/8" I-Joists.I'd just need some fastener to prevent the joist from being able to roll sideways.
jdebree - So if I am doing my math correct, you attached a 12" (assuming 2x12?) ledger board 4" up from the bottom of your first 6" core block. I assume you cast in some anchor bolts or j bolts on horizontal to mount the ledger board with? Then, you hung your joists on this ledger with standard joist hangers (affordable), and then laid your flooring over the joists, making sure each joist was flush with the top of the ledger board to ensure the flooring was level, or at least flat. Did I make any mistakes on that picture in my mind? I don't know how you would end up with 8' ceiling if you mounted the ledger flush with the top of the 8" core block, as that would mean your floor was flush with the *base* of the first 8" core block, but as you said it helps lock in the walls, so I'm picturing your ledger board 4" high up on the 6" core block. This would also mean your next course of 6" core block was set flush with the top of the joist/ledger plane. At this point, that is my best idea I have came up with. But you mentioned having to cut the block to get things to line up, and I'm not sure what you cut. Do you just mean a length difference between 6" core and 8" core blocks, or what was it that you cut on the basement blocks?
Joe - Thanks. I kept finding that bracket but could not figure out for the life of me how it held a ledger. Turns out that's the initial piece used for rigidity and the second bracket just uses that metal as an anchor point, eh? I can see it being beneficial if you want flush mounted anchors on the ledger, and saving the time it takes to cut plywood scraps to hold anchor bolts in place. Does it offer better support than an anchor bolt? I'm thinking I have more time and money, so I don't mind taking more time to make a mounting system. I assume that never would fail in concrete, the anchor plate? No reaction, and probably recommended to run something through the two hole that are inside the icf wall to add extra pull-out resistance?
I would not stay upstairs in a tornado if I was aware there was one. I'd just like the added protection to my home by having the concrete walls over a 2x6 or 2x8 timber framed home. The insulation alone should be my driving choice, but instead I am looking for more than just that...so noise and weather protection are heavy hitters on my decision making. 4" just seems like it would not be adequate if going for the rigidity of the concrete system. Thoughts? If I saw a tornado, I'd have my butt in the basement asap. lol. I do not plan on having a concrete or steel roof. I will use truss ties, somehow (haven't figured out how they will mount with the ICF wall and no framing) and perhaps a hip roof if budget allows it instead of a gable roof.
If I have to hire a pump truck for each pour, I won't be doing 3 pours! I am picturing a standard run of trucks for the footings and for the first pour if it were 4' or maybe even the 11'4" pour. But after that, I'd have pump truck. My only concern with the 4' first pour is the cold joint, but I have been reassured that you all believe as long as I have enough re bar sticking up, I shouldn't worry about the cold joint, yes? I am in touch with Fox Blocks, but haven't heard back lately.
Plus, I like getting the outside expert opinion and not just one or two people trying to sell a product. They are good people, though.
emmet - That's good advice. Assuming I use those anchors, too. I don't mind having a baffle that is 7' 2" as long as it's against a wall. The rest of the ceiling would all be 8' which I am happy with. The round ducting is the only thing that would jut below the joists, along the LVL or Steel beam for the open living area. The rest of the rooms would have a support wall down the middle of the home.
newbostonconst - that's a clever idea. Good thinking with the plastic to prevent capillary action. It would work even better for me with 8" basement. I suppose that's the most cost effective way, cutting the foam for each joist to rest in. You'd have to set the joists prior to pour though, yes? To get them to fit perfectly in the pocket.
