A Guide for Building with Metal SIPs
Last Post 17 Apr 2016 11:04 PM by phil-vegas. 82 Replies.
Page 3 of 5 << < 12345 > >>
25 Apr 2012 10:57 AM
100+ Tips for Building with Metal SIPs find it on Kindle and Nook. Here are some more excerpts from the chapter on Specification & Properties. 20. Every 10 feet of panel length expands as much a 1/16th inch in moderate temperature differentials. 21. Aluminum faced panels are about 50% lighter and easier to cut than steel faced panels. 22. Steel faced panels have around a 25% better screw holding capacity than Aluminum faced panels. 23. Due to galvanic reaction, Steel fasteners will rust when used with Aluminum faced panels in a marine environment.
26 Apr 2012 06:06 AM
Posted By JeffD on 25 Apr 2012 10:57 AM
100+ Tips for Building with Metal SIPs find it on Kindle. Here are some more excerpts from the chapter on Specification & Properties. 20. Every 10 feet of panel length expands as much a 1/16th inch in moderate temperature differentials.
So how much would an EPS steel skinned SIP expand, that sees a 30 degree temperature differential in less than 15 hours???
02 May 2012 07:08 PM
I gleaned this piece of information from a sheet metal expansion table in a SMACNA manual years ago. I do not have access to one. I would think it would be about the same. If it were more it would be very little more. Thermal expansion as it relates to steel faced panels is generall not a problem. On the other hand aluminum faced SIPs have twice the expansion rate of steel and can be a problem. A 20' Aluminum faced SIP could move 1/4 inch. That is enough to break weather seals and pull out fasteners.
03 May 2012 07:21 AM
Steel's thermal expansion is about the same as concrete, aluminum is double that of steel
20 Jun 2012 11:28 AM
100+ Tips for Building with Metal SIPs find it on Kindle and Nook. Here are some excerpts from the chapter on Design & Engineering.
21. Most door and window manufacturers do not have installation details showing metal construction. One way around this is to frame the opening with a treated wood buck.
22. Deciding on a plumb fascia or square fascia at the roof edge early in the design is very important, because this effects roof panel lengths, the package components, and the amount of panel cutting that will be required.
23. The underside of roof overhangs and porch roofs can be left exposed for a durable and clean looking finish, but keep in mind any exposed fasteners or channels that may need to be covered with trim.
20 Jun 2012 11:17 PM
Posted By JeffD on 02 May 2012 07:08 PM
All materials have expansion rates but that is why I believe a steel SIP is far better than an aluminum SIP. Wood also expands and contracts with temperatures and humidity. Even window glass moves with temperatures.
28 Jul 2012 09:25 PM
10. Gable roofs are easier and more economical to build than hip roofs.
11. 4 inch to 6 inch thick roof panels can, in most cases, cantilever up to 4 feet without support.
12. Smaller roofs intersecting a main roof should overlay the main roof in most cases unless extensive framing is added.
08 Oct 2012 02:56 PM
Lbear, I have seen aluminum skinned SIPs react with steel fasteners and cause them to rust prematurly. This will definately happen in a marine environment.
29 Nov 2012 10:56 AM
16. Support of dropped ceilings should be thought out carefully because the familiar bottom chord of the truss is no longer present.
17. Panel homes are very air tight, so thought must be given to indoor air quality in terms of ventilation.
18. Because there are no truss bottom chords, panel wall heights must allow for the thickness of ceiling framing.
19. Because a panel home is 30 to 50% more energy efficient mechanical systems can be down sized accordingly.
29 Nov 2012 11:28 AM
Know of any steel sip suppliers/builders in upper midwest? (MN).
29 Nov 2012 03:36 PM
Posted By slenzen on 29 Nov 2012 11:28 AM
slenzen;
PermaTherm Inc. ships to the lower 48 and Alaska
30 Nov 2012 12:54 PM
thanks, here is my crude prelim design, just starting to investigate pros/cons of various building methods.
south facing lake lot in MN w/ terrace sloped lot, passive solar design.  Won't be quite that much glass on the south face lakeside, haha.
13 Dec 2012 11:13 AM
I see one in upper MW that does steel SIPs but they just add the steel to the osb sip. Wonder why they do that?
28 Dec 2012 04:41 PM
The steel sheet acts as a vapor/moisture barrier and improves structural characteristics a bit.
29 Dec 2012 07:35 AM
This home currently being built in Land O Lakes, FL. demonstrates siding being applied directly skin used as vapor barrier
r.
04 May 2013 08:16 AM
100+ Tips for Building with Metal SIPs find it on Kindle or at Smashwords.com. Here's some excerpts from the chapter on Design and Engineering:
34. Roof panels can transmit the sound of heavy rains, so provide acoustical control measures or drop ceilings.
35. Beware of synthetic stucco exterior finish systems because they cannot withstand the expansion and contraction of the panels. Eventually the panel joints will telegraph through the finish and be visible.
36. Panel structures are typically 50% lighter than conventionally built structures, so make sure your foundations reflect this with reduced footer widths.
05 May 2013 12:13 AM
Posted By JeffD on 04 May 2013 08:16 AM
#34 - For my future project I chose the SoundProofing Clips for my Steel SIP roof to decouple the Steel SIP ceiling from the drywall. Still not sure which model I should get but they will decouple the Steel SIP ceiling from the drywall that will be attached below it. It will also allow space to run wiring. The rubber isolator model has great sound decoupling numbers.
#35 - How about where a synthetic stucco vertical wall (ICF) meets the steel SIP roof, how does one detail that area for the transition? You have 2 dissimilar surfaces/materials. Do you just run the stucco up the steel SIP roof and stop?
05 May 2013 04:08 PM
LBear A self adhering roll membrane I have found does a great job of absorbing the impact of heavy rain. Your solution will help as well. I would use a good quality elastomeric sealant.
09 Feb 2014 03:08 PM
27. The best way to install electrical wiring on panel walls is to use 1 1/2 inch deep duplex boxes with reducer plates. This works well with 1 1/2 inch furring strips.
28. If one installs an insulated garage door, the garage space becomes easily air-conditioned and a very usable and comfortable space.
29. Spaces above ceilings are partially air-conditioned, and make great storage or mechanical space. Vents to adjoining spaces should be installed to allow some air flow and avoid stagnation.
ricky_005User is Offline
13 Feb 2014 10:31 AM
After spending many hours researching metal skinned SIP, I have come to the conclusion they are only useful in very simple small one story box designs. As complexity increases beyond a simple box you would need to add structural steel which would run construction cost up rapidly.
If your building a small home and not concerned about the character of the homes exterior it would be a excellent way to construct.
But I think the product is overall best suited to the metal building industry where you attach the metal insulated SIP skins to a base channel and sidewall/endwall girts and the metal building frame takes the majority of the dead/live/wind/seismic loads.
If you find this untrue in your opinion, please post some photos and links to high end homes utilizing it in a roof and wall designs to prove me wrong. Understand though ... I think its a great product and would like to use it in my new home build, but the limitations it creates requires heavy structural steel framing to add design flexibility and the down fall is cost escalates QUICKLY.
