Wood is no good!
Last Post 16 Feb 2009 07:46 AM by boettg33. 81 Replies.
Topic is locked
Page 1 of 512345 > >>
31 Dec 2008 06:53 PM
This discussion started on another thread, and I thought it was worthy of posting here.
Wood framing, sheathing is not suitable for exterior walls of a structure. It molds, rots, leaks air. A house of wood will blow away, float away and will not last as long as a masonry house nor will it be as energy efficient as ICFs. If only there was an economical roof structure alternative.
While SIPs are way above wood framing in energy efficiency and less likely to mold, they still are usually made with wood, which can rot and mold. I have not seen the effects of windstorm or fire to a SIP house, SIPs are not as strong as concrete and masonry. SIPs place is for roofs.
Wood is for interior doors, cabinets and furniture.
aardvarcusUser is Offline
01 Jan 2009 05:43 PM
I am not sure if you have ever seen a properly built stick frame house. I'm not talking the hunks of garbage you see a dime a dozen on streetcorners, I'm taking about drainage planes, metal storm ties, all screw construction, double plywood diaphragms, foam sheathing, timber framing, the whole nine yards. I find it a little unfair to lump all of one style of houses together. I am sure I could find a few ICF houses that weren't built properly, but it would be unfair to judge them all by those few. As far as energy efficiency, there have been and continue to be highly energy efficient houses built using stick framing. Just think spray foam, double stud, or foam sheathing.
I admit, masonry is much stronger, which is why I like to wrap my wood frames with a brick/stone cover. However, the exterior of an ICF house is not masonry, it is foam. In a fire or extreme weather event, even if the concrete core remained solid, the outer foam would be completely demolished and torn to bits. If you want to have a truly solid house, put your masonry outside your foam, not vise versa. You also have to consider that unless you build a monolithic dome, your roof isn't going to be masonry, and will be susceptible to damage. What good will it do if after a storm you come back to nothing but solid concrete walls, with the roof gone, insides destroyed, and the foam covering blown away?
It's not that I dislike ICF's, I just don't buy into the idea of blindly following the current trend and writing off everything else as a hunk of garbage. I believe there are many ways and styles of properly building a house, and it is up to each person to decide for themselves how they want to approach it.
01 Jan 2009 07:11 PM
You are right, I have never even heard of a house built with all those features. What does that kind of construction cost? And yet still inferior. So much more room for error, drainage planes, vapor barrier, house wrap and so on; unnecessary with ICFs
Although a masonry veneer on a wood house will help, it is still just a veneer. A masonry veneer on a ICF house, that's a house! Wind will not blow off the EPS on an ICF house, debris may dent it, but still a fraction of the damage to a wood house, the same goes for fire. As far as a wood framed house, the stronger the walls the less likely the roof will be lost in a windstorm. And what good is it to still have walls, you and your family would be alive.
Foam sandwiched by concrete is not as strong, take T-mass vs ICFs. A t-mass with 6" of concrete is 2" concrete 2" XPS and 4" concrete, that is not as strong or as well insulated as ICF with a 6" core. What would you cover the exposed concrete with? And as far as protecting the insulation of an ICF it is covered both sides.
Concrete and EPS is hardly a trend. Concrete structures have been around for thousands of years and EPS and ICFs over 40 years.
jdebreeUser is Offline
03 Jan 2009 05:26 PM
I don't think any one type of construction is best in all situations. I grew up in a 200 y/o house in CT, and it is still strong and straight. I really can't believe foam is going to actually last that long. I work in the plastics industry, and all plastics seem to degrade with time. One of the biggest problems is cost, of course. It's pretty hard for most building methods to compete with stick construction on cost. I've considered ICF and steel SIP's, but both cost so much more than stick, I really can't afford it. I'll be dead in 20-30 years anyhow, so what do I care? Done properly, like the timber frame house I grew up in, most building methods are going to be just fine. I guarantee that almost any house can be damaged by a severe storm. During Hurricane Andrew in south FL, a 2 ton chunk of reinforced concrete that was part of a military building was found several miles away. In that case, the only safe place is under ground.
03 Jan 2009 06:02 PM
Expanded Polystyrene has a life expectancy of hundreds of years when not exposed to ultraviolet light. I bet your 200 year timber frame house was part masonry.
With an added build cost of 3-5% and a similar or lower cost of ownership, much longer structure life, safer, more comfortable, quieter and so on. ICFs are a no-brainer. Skip the granite counter tops and build a better house.
"I guarantee that almost any house can be damaged by a severe storm" of course, but there is no comparison in strength. We had two kids die in two tornadoes here, dead because they were in a stick framed house. And I do not believe a "2 ton chunk of reinforced concrete" blew several miles.
ManfredUser is Offline
06 Jan 2009 09:21 AM
icfconstruction, you opened up a can of worms here. It all has to do with the believe system you operate under. I am an avid believer that overall ICF is the better way to construct. But there are other products out there, depending on location, that deserve mentioning.
TNT blast test by the US ARMY in Florida found ICF filled with concrete to be one of the most durable building products on the market right now. I'd say that carries some weight when considering "a safe structure". Everything crumbles when hit by a inter-continental missile. But I know ICFs can be engineered in such a way that they can withstand an F5 tornado. The only weak point is the roof, and if the roof is intergrated with the walls with rebar connects and concrete - you basically have a bunker. Put roller shutters on your windows and doors ( i know of some tested to 187mph) and you would not feel safe inside?
Today's wood construction should be limited to fine carpentry. So, yes, wood is bad for an envelope of a house. We use an average of 14 trees per house for the exterior structure of a house. Ouch! Even if only 400000 houses were build each year with lumber that would be how much? Is that not a Forest that is gone for 20-30 years?
gregjUser is Offline
13 Jan 2009 01:17 PM
Posted By Manfred on 01/06/2009 9:21 AM
There are certainly many pros and cons to consider in the lumber vs concrete house debate but I don't think you can pull out the green card and use it against lumber and for concrete.
I think it has been pretty well established that the process required to manufacture cement creates a huge amount of greenhouse gases. Using lumber promotes responsible stewardship of private forests because their use as lumber gives these forests financial value. These forests actually consume greenhouse gases (CO2) and sequester the CO2 within the growing trees as well as the final lumber. So lumber use reduces greenhouse gases and keeps it tied up until the lumber is burned or rots. In a well built structure that should not occur for a very long time.
rykertestUser is Offline
13 Jan 2009 01:40 PM
Posted By aardvarcus on 01/01/2009 5:43 PM
Man that would be once very nice stick built house, but sadly, I'd bet not even 2% of homes built today are of the caliber.  Homes today for the msot part are slapped up as fast as possible with no regard for any sort of longevity.  I think thats why older homes are so popular.  They were built right, and built to last.
However, even the best stick built home cannot compare to icf in any way, even cost as it currently stands.  The foam is not a light weight item and if a storm is so bad that is rips the foam off the walls, I'd still rather be in an icf home as the stick built ones around me are long gone with their occupants and only a foundation remains.
While it would suck to live in this area, at least there is something to come back too.
  http://www.zeropowerhouse.com/pic/concrete_home1_lrg.jpg
I agree that no technology should be blindly followed, and not all other is garbage.  But in almost any catagory, icf winds hands down.  I don't direct this at you aard, but in general why do people still fight icf as the superior building product to date?  The facts speak for themselves.
13 Jan 2009 01:47 PM
Posted By gregj on 01/13/2009 1:17 PM
I respectfully disagree.  The longevity of concrete products or in this case concrete homes, makes them quite "green".  If we stopped slashing forests, even harvesting in a responsible way and used the concrete as the main building product, the benefits (trees cleaning co2) would far out weight the negatives (concrete producing greenhouse gases).  Just think about how many homes would be built and rebuilt and even rebuilt again before a concrete home would need to be.
13 Jan 2009 03:39 PM
As it stands today the cement industry by itself emits 5% of the total CO2 emissions for the entire earth. If we switched all house construction from lumber to concrete what would that number skyrocket to????
Your terminology indicates that your reasoning is based on emotion rather than facts. There are no maniacs slashing down forests in a wild anti-tree, kill the spotted owls rage. There are lumberjacks who cut trees for use as lumber. They don't hate trees, they love them because trees are their source of income. Lumber companies have a vested interest in a sustainable forestry program and plant more trees than they cut down.
eliminating the lumber industry would not result in more trees (and therefore reduced CO2) as you imply. There are huge private forests in the US that are forests today only because of there financial value as lumber. If that goes away, those forests will be cut down to make way for some other income producing crops that will not sequester C02 like trees and lumber do. I think you are vastly underestimating the quantity of greenhouse gases emitted to produce cement.
I'm thinking about it and am "stumped" (pun intended). Are they regularly tearing down and replacing houses in your neighborhood? They don't around here. The only time a house gets torn down is because of a new road or shopping center going in and that would happen whether the house was lumber or concrete. But even if they did need to be rebuilt it doesn't make them less green because the use of lumber promotes forestation which consumes greenhouse gases. The though of switching all house construction to concrete must keep Al Gore tossing and turning all night worrying about the massive increase in C02 emissions.
13 Jan 2009 05:06 PM
As a matter of fact yes they do regularly tear down (apart) mold ridden wood framed houses in MN. Even though the moldy houses are demolished completely the mold mitigation often costs as much or more than the original construction. Wood framed category one constructed houses are very unforgiving, if one thing is done wrong or if one little thing is missed or not maintained such as caulk, there will be big problems with big lawsuits.
My post was not about alleged good or bad these systems, may or may not do to the environment. My point is wood framing is inferior in almost every way to masonry and concrete, especially ICFs. Even in the unlikely event a wood house is built the way it should, it will still blow or float away. In a storm a wood house could kill you or yours, http://www.startribune.com/local/north/37418339.html
13 Jan 2009 07:28 PM
About the green factor-
99.99% of the wood you buy today isn't from slashed old growth forests. Using lots of wood from managed forests is actually eco-friendly. Undisturbed forests are carbon neutral, because as trees die they fall, rot, and re-release all the carbon they previously absorbed, with a net effect of nothing. However, if you keep the wood from rotting and replant a new tree, you will have a net carbon absorption. And what better way to keep the wood from rotting than to build a house with it?
Also, just do a search on concrete and the environment. It is one of the WORST materials we use today. I am not saying we shouldn't use it, as I plan on using quite a bit of it in my next house, but don't act like it is eco-friendly.
About structural strength- I admit a high quality properly installed concrete wall will be stronger than a high quality properly installed wood wall. But any old slapped together concrete wall will not stand up to a high quality wood wall.
What is concrete's biggest downfall? Tensile strength. The forces on a wall in a storm are very complex as the wind swirls in and around the house in different ways, making the walls attempt to twist, bend, and contort. You have to treat the wall like it is a beam, and for a concrete beam to handle the tensile forces, it must be reinforced with rebar. The rebar also needs to go where the forces are, which means outer and inner bars all throughout the walls, not just one slapped in the middle. If you do not put adequate rebar in the wall, it will crack or worse shear off.
Everyone has seen how stick framed houses today are. It's not the fault of the building material, it is the contractors who don't care. Every single corner that can be cut has, and some that can't be cut have been anyway. What do you think contractors will do when they start using ICFs? You won't be able to find a stick of rebar in the whole wall. You will also probably finding some quick set chemicals mixed in too. Any properly vibrated? Forget it.
Also, in any storm situation, the roof or roof attachment is going to be the first point of failure, not the wall. It doesn't matter if your wall can stand up to 100,000,000 MPH winds if your roof isn't strong enough to withstand it.
So how can anyone say that any old house built with ICF's is going to be stronger than my house just because my house uses wood in the walls? My rafters are 2*12's , and they are screwed into my 8*16 timbers and my load bearing ridge beam which is set into my solid masonry fireplace on one side and with solid wood down to the bond beam in the top of my basement wall on the other. Even though they aren't up to reinforced concrete standards, my double diaphragm 2*6 walls are incredible strong. Just because a house has concrete in the walls doesn't immediately make it structurally superior to every single wood framed house in existence.
What am I getting at? Its not the material, it is the Design and Proper Installation of the material that matters. There is no material that is foolproof, even concrete.
13 Jan 2009 08:13 PM
Posted By gregj on 01/13/2009 3:39 PM
WRONG.
  • Cement production is responsible for about 1% of the greenhouse gases emitted in the US. 3% worldwide.
  • More than half (60%) of the CO2 emitted during cement production is due to calcination, a chemical reaction from heating limestone.
  • Concrete reabsorbs most of the CO2 emitted by calcination during the time it serves its useful life, and shortly after it is demolished and crushed.
I think you need to do some research man, your approach is very nieve and obviously written based on emotion.  Just do a quick search on youtube or yahoo or goggle for clear cutting 2008 and that's just the stuff in this country.  Now look at the rainforests and what is being done there.  Acres upon acres are lost each and every day.  And this reply is coming not from some pachulee wearing hippie, but a staunch conservative republican.  it's just facts man and you not acknowledging it doesn't change that.  I don't fault the pick and choose selection process that is more common practice in the US Lumber Industry today, but don't act like clear cutting is a thing of the past, thats just ignorant.
I did not imply eliminating the lumber industry.  And you are overestimating the CO2 produced.
Anything that keeps Al Gore nervous I'm all for.  WHerever you live must be a wonderful place, because here in the real world, houses are built and sometimes torn down, thats just life.  Wood has it's place and using sustainable wood is green.  However, for sutructural purposes it is inferior to concrete, which is also green.  I am not anti wood, I am pro concrete so calm down.
13 Jan 2009 08:26 PM
First off I don't give two craps about Al Gore, but he did invent wood and concrete.
Aardvarcus,
About the roof failing first from windstorm, not necessarily true. But if the walls go, the roof will. And a roof on a better wall will withstand a whole lot more.
We had two kids in the past three years die in MN tornadoes, both died when the wood framed walls and roof fell in on them. They would be alive it they had been in an ICF house!
13 Jan 2009 08:29 PM
Posted By aardvarcus on 01/13/2009 7:28 PM
and 87.5% of facts are made up on the spot. lol  JK. Concrete IS green, you guys need to do some research seriously.  Wood has it's place and yes managed forests are the way to go.  But a home built with concrete is a superior AND green home.
You make a valid point but with ICF, rebar is a standard practice to greatly reduce this issue.  Also the ICF process of curing the concrete increases that strength to ROUGHLY 5000 psi, or more if desired.  Now show me a stick built wall that can equate that.  And thats my point.  If the big one comes unless you are in an abandoned nuclear silo a mile underground it won't matter what you live in.  But for the vast majority of things our homes encounter, concrete is a superior building product.
Valid point.
While there is no material that is totally foolproof, I think the OP was not stating that but that concrete is superior to wood.  Of course there are numerous variables to consider but if you had 2 houses built as they should be, 1 concrete and 1 wood; the concrete house will be a superior house.  Does it mean that the wood house is a bad home?  No, you could have a very nice energy efficient stick built home, but it will not equal the concrete home, which is better.  I'm a good looking guy, rather good looking in fact, but that doesn't mean that there are not other better looking guys out there.  I am your stick built home you described above.  lol
13 Jan 2009 08:30 PM
Posted By ICFconstruction on 01/13/2009 8:26 PM
Aardvarcus,
no he invented the internet.
13 Jan 2009 08:46 PM
Concrete IS Green!
[b] »  [/b]Concrete is produced locally from abundant natural resources.
[b] »[/b][b]  [/b]Concrete can be made with reclaimed industrial materials that
      would otherwise burden landfills.
[b] »[/b][b]  [/b]Recycled materials in concrete reduce CO2 emissions.
[b] »[/b][b]  [/b]At the end of a concrete building or pavement’s usable life,
      concrete can be recycled.
[b] »[/b][b]  [/b]Pervious concrete percolates stormwater into soil, recharging
      aquifers and preventing polluted runoff from overwhelming
      streams and lakes.
[b] »[/b][b]  [/b]Concrete’s thermal mass reduces temperature swings in
      buildings and conserves energy.
[b] »[/b][b]  [/b]Use of Insulating Concrete Form for above-grade wall systems
      provides for increased R values, reducing heating, cooling and
      infrastructure costs.
[b] »[/b][b]  [/b] Concrete’s light color reduces the heat island effect, lowering
      urban energy use.
[b] »[/b][b]  [/b]Concrete’s light color reflects more light at night, reducing
      lighting infrastructure and energy costs.
[b] »[/b][b]  [/b]Impervious concrete roofs support green landscaping, reducing
      water runoff and reducing heat island effect.
[b] »[/b][b]  [/b] Concrete structures are durable.
13 Jan 2009 08:49 PM
Air and the Internet.
I forgot to say "tensile strength" reinforced concrete has excellent tensile strength...That is why it is the material of choice for things like bridges.
14 Jan 2009 10:33 AM
Rykertest
Here is my reference, Show me yours:
http://www.wbcsdcement.org/pdf/tf1/prghgt42.pdf Cement industry emits 5% of C02 globally
So how much rainforest wood is used for framing houses in the US??? I've only seen North American sources for framing lumber. I'm not condoning rainforest destruction but to my knowledge there is no connection between house framing in the US and rainforest destruction.
I do live in a wonderful place and am quite calm. I just don't like it when people try to say building with lumber isn't green as an argument for concrete construction. I also like concrete construction and my next house will likely be ICF. But why bring up bogus arguments like the green issue. Those twisted studs sold as lumber today are new growth forests that are planted as fast as they are harvested and their growth and use is a net good for the environment. Cement is a great building material but it does have the very real negative consequence of CO2 emission that needs to be addressed.
14 Jan 2009 10:39 AM
I wouldn't care if the use of lumber caused world piece.
My point is was made in the original post, but I guess those points are irrefutable.
Topic is locked
