The appropriate answer to your question about using SIPs for roofs is based on several major issues:
1. The capability of the fabricator - if they have state-of-the-art routers and C & C machines, its not a problem at all to do complex roofs with Hips, Valleys, etc. We do it all the time and have done extremely complex roof designs with SIPs.
2. The installer's experience is of major importance: Some roof projects are not for 'beginner's' simply because they often do not really understand the SIP fabricating process and what is available - in most cases they do not recognize what can be done with a good fabricator and they do not ask the right questions. As with all good construction, and especially with SIPs, the better-educated and experienced SIP installer will know how to make the roof work with SIPs.
Experience is a major consideration in building with any altnerative technology and can be greatly assisted if the supplier is also doing the design and engineering, which asssits in the utilization of the SIPs in the building process.
SIPs are only llimited by experience, not technology.
Best of Luck,
Gary Radzat, President
Shell Building Systems, LLC
LINK
