Loop Material Question
Last Post 22 Apr 2008 08:35 AM by TechGromit. 2 Replies.
pjc57User is Offline
21 Apr 2008 12:13 AM
In a DX system they use copper tubing, backfilled with sand or grouted in. In a Closed Loop system they use plastic tubing grouted in. Because the copper is more efficient in thermal transfer, the DX system's wells are less than 100' deep as compared to 100' to 400' deep for the Closed Loop. If the above is correct, why don't they use copper in the Closed Loop system?
Paul
21 Apr 2008 10:58 AM
The DX copper loop is already a closed loop system.
I'm assuming you mean a 'water loop' when you say 'closed loop'.
If they were to use copper in the water loop system, they may have problems with electrolysis inside the tubing. That's my guess on why. Other than that, I don't know. Maybe because of the cost of the copper.
TechGromitUser is Offline
Posted By pjc57 on 04/21/2008 12:13 AM
Because the copper is more efficient in thermal transfer ... If the above is correct, why don't they use copper in the Closed Loop system?
As someone else pointed out in another topic thread, although copper has better thermal transfer, a 1 inch PVC pipe has something like 10 times the surface area for the thermal transfer, so even thou the PVC pipe isn't a good, the larger size of the pipe (thus larger surface area) used more than makes up for the difference.
I don't see why copper couldn't be used for a closed loop water system, but it's proably more cost effective to use PVC piping.
People Online People Online: Visitors Visitors: 231 Members Members: 0 Total Total: 231
