need new heat pumpe 3 or 4 tons? 5 or 7 series WF ?
Last Post 19 Jul 2018 05:58 PM by arkie6. 4 Replies.
turbov6camaroUser is Offline
13 Jul 2018 09:23 PM
Hello I need some outside advice before we Drop 20K on this. basically our old mammoth system is 3.5 ton. its dying. Currently it is cooling "okay" but is not really dehumidifying, its running nearly constantly current loop out = 96 current loop in =84 (st louis area, its hot right now) (IR on the metal parts 6 inches from my pumps) 3 companies, 1st only sells climatemaster. 2 sell water furnace this price are within $1000 to 2000 for the CM 2nd vendor one will not sell me a series 7, even the 3 ton, saying we don't have the loop for even a 3 ton unit. so they want to do 3 ton 5 series 3rd (this vender sell both CM and WF) (this vendor does the well drilling for geo in this area) one is recommending the 7 series 4 ton, this thinking is our loops are 450feet and this makes with the current temps we are seeing the system (system was drilled in 1987 and 125ft per ton was used at that time vise the 150 now) 450/125=3.6 ton the 4 ton unit can handle full load and since it variable will not have to run at the full 4 tons, except on the extreme hot/cold days we can run on this for s year or 2 and if it keeps over running the loop we can dill new loops in a couple years at a cost of about $8K the thought is a 3 unit will be undersized and run in stage 2 for a 5 series or full bore for the 7 and not really be efficient house is 2500 sq feet, slab, single story thoughts ?
newbostonconstUser is Offline
16 Jul 2018 11:03 AM
Are you thinking your loop temps are high for your unit? (I haven't looked at the specs of your unit)
Is the unit really dying? Or is the unit fine and you just need more loop?
What makes you think it is dying other then not taking humidity out?.
What is your indoor humidity at?
17 Jul 2018 04:44 AM
humidity will not go below 60%. unit has been fine until this year
19 Jul 2018 06:13 AM
You might want to look here:
https://www.bing.com/search?q=humidity+removal&qs=AS&pq=humidity+re&sk=AS1&sc=8-11&cvid=D670340CC0404ECFA02F71800BC39531&FORM=QBLH&sp=2&ghc=1
Probably 'allot' less expensive to remove humidity as long as your house is staying cool in this hot weather. Have you talked to the original HVAC that installed your system? I'm ALL for GEO but all my experiences, they want to charge 'outrageous' prices to make 'huge' profits......because it's new. Just like the $900 cell phone!!!!!!
arkie6User is Offline
He posted the following over on the Geoexchange Forum when I asked if his condensate was draining out properly: "the system stopped draining out the hose, it is not cloged, its dumping water all over the floor now, the system is running all day but the humidity is 60-65%".
If the condensate water isn't being removed from the building envelope, then the system can't reduce the humidity inside.
Here is the thread on the other forum: https://www.geoexchange.org/forum/t...s-wf.7540/
People Online People Online: Visitors Visitors: 137 Members Members: 0 Total Total: 137
